Clear coat curing times?
Old 12-22-2008, 07:35 PM
HamiltonRex's Avatar
Default Clear coat curing times?
Hi, i painted a small section of my car, the rear.
However, im concerned if the clear coat is fully cured yet, as well as the base coat. The night it was sprayed it was aprox 14 deg C above freezing.
However, after it was sprayed, it stayed at that temp for about 3 hours, than it was well below freezing for about a day, than i had it up to about 10 deg C for maybe 5 hours, and than cold for today, well ive had the stove going and its about 15deg C in there and it will be for about 8 hours total.
Does clear and base cure in sub zero temps, the extra clear i had in a jar turned solid, and i mixed everything properly. Just want to make sure im giving this enough time.
Thanks!
Old 12-23-2008, 02:55 AM
Disease's Avatar
Default Re: Clear coat curing times?
Touch it and find out. LOL don't do that. I would not know just could'nt resist. Should be dry to touch but still soft, my guess.
Old 12-24-2008, 04:50 PM
precisionsc54's Avatar
It might haze over if it didnt get to fully cure through
Old 12-25-2008, 12:00 PM
prelude1897's Avatar
Clear coat doesn't take too long to dry depending on how many coats you put on, and how well you mixed it. The more hardener you put in it, the quicker it'll dry, but I still don't suggest going way over the mixture ratio
Old 12-25-2008, 04:46 PM
FearTheH's Avatar
Best thing to do is use the proper ratio, and if you want it to look good, spray it in a controlled environment. I always allow mine to cure for 48 hrs at 70-75 degrees F. That's more than most would do but I have never had a complaint nor had to repaint a car. But with the temperature bouncing around it can cause the clear coat to become foggy. Hope this helps man. Good luck!
Old 01-22-2009, 02:11 PM
clear coat cured about 3 days, at temperatures between -15 deg C and +15 deg C depending on how much wood i had in the stove, it looks fine now.
Thanks everyone.
Old 02-11-2009, 10:06 AM
G0TB00ST's Avatar
Location: ON A STREET NEAR YOU BREAKING TRACTION ON ALL 4 WHEELS!
Interesting info to know!
fotidiox
Paint and Body
05-30-2012 06:27 PM
SyDuck
Paint and Body
09-23-2007 08:35 AM
copperfox
03-09-2006 09:58 AM
Quick Reply: Clear coat curing times?
