1st time painting rims
Old 08-23-2009, 04:41 PM
madblkscientist's Avatar
Default 1st time painting rims
pics dont do justice but the rims came out looking badass
1st i took them off the car
2nd I washed them with water soap degreaser
3rd dried and rub them done with rubing alcohol 2 remove what ever grease oil or crap so i dont clog up sand paper
4th i sand all the dented and rough spots with 80 grit not the whole rim
5th I primed with high build to even out all the spots i sanded with 80 to get smooth only spots not whole rim
6th I wet sanded the whole rim with 220 then 400
7th I let drie then I taped off areas like the tire that I did not want painted
8th I went advance auto and purchased a dark metallic gray rim paint and clear coat
9th I gave it like 2 light coats then 1 wet coat of base then 2 coats of clear
I waited 10 mins between coats Then left it out 2 drie for 24 hours
Old 08-23-2009, 04:59 PM
Default Re: 1st time painting rims
B4 rims installed on car
washed, cleaned,saned, and masked off
1st coat
2nd coat
finished product
40 bucks and a day of preping and painting and i still got paint left over
Old 08-23-2009, 05:05 PM
The reason I painted the rims is because for now I rather put the money for buying new ones into the motor and tuning hardware instead,also because the shop that painted the car got paint n primer all over them,and for a diy project i mean if it turned out good why not
but after all the hard work and getting high off fumes the rim shop told me the rims cant b balanced cause they r bent, o well i still enjoyed painting them
ill post up more pics later of other rims imma paint
Old 08-23-2009, 06:04 PM
my work shop
replies would b nice
Old 08-23-2009, 08:41 PM
Civic-Kids's Avatar
nice... :D
Old 08-23-2009, 09:13 PM
thanx
Old 08-23-2009, 10:38 PM
Duc_du's Avatar
look better than how it use to look. stupid question but what does it mean to balance the rims???
Old 08-23-2009, 11:10 PM
they put weights on the inside of the rim so at high speeds they dont hop up and down due to the rims being heavy on one side
Old 08-24-2009, 12:20 AM
DB1_559's Avatar
lol so it dont have no weird vibration or weird tire wear, balance it all for comfort i suggest alloy 2 balance ftw!!!! forget static balance also make sure it dont get zero'd out,make sure they get it .20 and below at work i will not allow my tire/rim to leave if it is not balance rite!!!!
Old 08-24-2009, 11:02 AM
they're bent so they say so it aint worth balancing gonna replace with other used or brand new ones rims are reasonable these days
Old 08-24-2009, 12:03 PM
Duc_du's Avatar
thanks. so what is the process behind balancing? just out of curiousity because i never got my wheel balance before...
Old 08-24-2009, 12:06 PM
im sure u did all rims get balanced when they get new tires cause tires could b off too and balancing corrects this
they put it on this machine that simulates high speed revolutions and it has sensors that detect un equal weight and tellthe tech where to add weight to balance the wheel
Old 08-24-2009, 12:09 PM
Duc_du's Avatar
ohhhhhhhhhhhhhhh. i never ask about it when i change tires so didnt know. thanks buddy
Old 08-24-2009, 12:16 PM
look in the back of ur rim or along the edge of the rim front and back u might see a lil removable metal clip those are weights
Old 08-24-2009, 12:19 PM
Duc_du's Avatar
if u have curbes and scratches doesnt it make it unbalance?
Old 08-24-2009, 12:20 PM
96 Civic DX's Avatar
Looks good. Are those 17"?
Old 08-24-2009, 12:36 PM
yup
Old 08-24-2009, 12:41 PM
What are you gonna do with them since they are bent?
Old 08-24-2009, 12:45 PM
imma take em to a shop and make sure they r or not bent or if they fix em if they're good imma keep 4 now till i get tired of them then sell if there good if not then the garbage lol
Old 08-24-2009, 12:49 PM
If they aren't fixable don't throw them away.
Give them to me for a few bucks
Old 08-24-2009, 12:53 PM
**** ill jus give em to u if they aren't
not gonna charge 4 bad rims
Old 08-24-2009, 12:56 PM
**** alright haha. I got dibs on them. Pm me if they are garbage.
Old 08-24-2009, 12:59 PM
ok
Old 08-24-2009, 01:01 PM
You should take a couple pics of them on the ride
Quick Reply: 1st time painting rims
