Paint prep. on Urathane lip ?????
Old 11-29-2007, 05:45 PM
Minh826's Avatar
Default Paint prep. on Urathane lip ?????
I've been wanting to paint a urathane itr lip but I heard there was a a special way you have to prep the surface, due to the release agent used in the molding process. Is there a chemical that i can use to clean it before paint work? Thanks in advance for any help...
Old 11-29-2007, 07:23 PM
powerflow's Avatar
Default Re: Paint prep. on Urathane lip ????? (Minh826)
If its raw plastic, wash w/ hot soapy water to remove the agent. Bake the part if possible to release any thing else that may be trapped. Wash again w/ hot soapy water. Prep w/ water and grey scothbrite and/or fine grit around 1000. Clean w/ raw plastic prep cleaner (BASF 902 for example). You can also try a dab of MEK on an inconspicuous area. If its ok wipe w/ MEK (dont try if your not comfortable doing it). Use a raw plastic adhesion promoter, preferably one from the paint sysem being used. Paint away.
Old 11-30-2007, 06:18 PM
Team Rukus's Avatar
if the part is brand new use a grey scuff pad. then completely clean it up with wax and grease remover. after thats dry spray adhesion promoter on it (1 light coat only) give it 5-10 mins and then spray your base coat paint and then clear coat make sure to clear adequate time between coats for them to dry properly.
fernando.
Paint and Body
03-02-2011 08:43 AM
TwoFaced
Paint and Body
02-02-2011 03:37 AM
mrtrinh
Paint and Body
09-10-2008 04:53 PM
Freshazzburu
07-26-2006 07:47 AM
BAYgasDC2
08-19-2005 02:29 PM
Quick Reply: Paint prep. on Urathane lip ?????
