acrylic enamel vs. acrylic urethane??? - Honda-Tech
Old 02-29-2008, 03:44 PM   #1
aznlaoboi315's Avatar
Default acrylic enamel vs. acrylic urethane???
I'm going to be spraying my civic championship white and seeing that from the factory ITR's had Single Stage NH-0 paint I've decided to use a single stage paint also. I noticed that a lot of paint shops sell single stage in either Acrylic Enamel or Acrylic Urethane. Does any body if there are distinct differences in the 2 acrylics? Like the shine or maybe even the durability?
aznlaoboi315 is offline   Reply With Quote
Old 02-29-2008, 05:21 PM   #2
powerflow's Avatar
Default Re: acrylic enamel vs. acrylic urethane??? (aznlaoboi315)
Acrylic enamel is a less advanced material, works great and can look great but it tends to to be less durable and age faster than urethane enamel. Its still a 2K catalyzed, chemical resistant paint but the urethane is more advanced.
Urethane enamel is very durable and flexible so it can expand/contract more compared to older less advanced paints. Its more of a current, up to date paint material. The high quality urethane clears have excellent high gloss characteristics also. Urethane can last a long time while looking fresh when kept up and properly maintained.
I don't shop around for paint much, but these are the two types of auto paints being used beside the newer water base. I've never really seen auto paint labeled as " acrylic urethane " only urethane enamel or acrylic enamel. Sounds like a sneaky way of labeling cheaper acrylic paint.
powerflow is offline   Reply With Quote
Old 02-29-2008, 05:41 PM   #3
Default Re: acrylic enamel vs. acrylic urethane??? (powerflow)
very good info thanks powerflow
buying paint is tricky I went on ebay and typed "Acrylic Urethane Paint" and it returned many results and then I typed "Urethane Enamel Paint" in the searchbox it came up with like 6 results. I'm going to be using either OMNI or ShopLine PPG brands for the single stage paint because the PPG Concept is too pricey.
Old 02-29-2008, 06:12 PM   #4
powerflow's Avatar
Check out this site. You may want to call them to see if they can offer competitive pricing to the ebay items. They also carry the BASF RM Diamont line, which is what I prefer to use.
http://www.ketone.com/
acrlylic urethane questions tasco Paint and Body 3 11-13-2011 10:27 AM
Help i got paint drips!!! DelSol12345 Paint and Body 1 03-30-2009 07:00 AM
Question about Acrylic Urethane Reducers reactone Paint and Body 7 11-16-2007 05:03 PM
quick question about paint? lamboextreme Honda / Acura 5 02-05-2007 10:51 PM
Honda Paint? dustin Acura Integra 18 10-19-2001 09:15 AM
Tags
acrylic, auto, automotive, car, enamal, enamel, enamels, omni, paint, ppg, single, stage, urethane, versus, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
