2K primer over canned duplicolor primers?
A guys I'm prepping my car for paint, and I'm doing small body repairs. Now after the repair I'm using some duplicolor canned high build primer(priming bondo area's) and self-etching primer(for metal spots). So once I'm done with the car i plan on shooting the whole car with some 2K polyester primer or a urethane primer.Which is better?????? Don't know which one yet BTW????? Feather fill????
Now would i run into any chemical reaction problems using canned then going over it with some 2k primer?
And do i need to stay with the same brands on everything? Like using a evercoat 2k then shooting the base with some ppg a no no???
Thanx for all ur help peep's.
Re: 2K primer over canned duplicolor primers?
nah you should be fine. i used duplicolor primer for spots i was doing work on and then sprayed the entire car with ppg primer and didnt have a problem. ill check the can cus i dont remember what kind it was.
t0p_sh0tta
Paint and Body
05-29-2007 06:16 AM
2k, build, california, car, compatible, duplicolor, hawaii, high, metal, paint, ppg, primer, shooting, southern, urethane
