Should a had a V8, Allmotorbrew's LSX Swap 2.0
Thanks to alot of people that have helped get this thing in full swing quick. Assaultech.com , Chasebays.com, DGR Suspension, Spec Clutches, Sikky.com, Dustin@Strafe, FTP Performance, Computechracing.com, tick-performance.com, if i forgot anyone else ill add them later.
Strafe Trunk
this is the way the car sat before the teardown
http://importalabama.com/articles/ca...g35-sedan.html
Motor
Assaultech.com,FTP Performance, Sikky.com
LQ9
Custom cam
Supporting valve train for cam
Fast 102MM intake manifold and throttle body
Sikky 7/8 headers with 3.5 inch collectors
Sikky Swap kit G35/350Z
Trans
Tick-performance.com
Bronze 1-4 Fork Pads
OEM 5-6 & Reverse Fork Pads
Billet 3-4 Synchronizer Keys (with upgraded springs)
New OEM 1-2, 5-6 & Reverse Keys & Springs
Carbon Fiber Synchronizer (blocker) Rings
Steel 3-4 Shift Fork
New 1-2 Synchronizer Assembly
New 3-4 Synchronizer Assembly
New Front Seal
New Rear Seal
Viper Style 2nd Gear
Spec 3+ clutch, Flywheel, and Throwout Bearing
Wiring/Fuel
Chasebaysonline.com, CJ-Motorsports
Chasebays Mil Spec LSX Harness
Chasebays Custom fuel return
CJ-Motorsports Fuel Correction kit
255 lph fuel pump
Chasebays LSX power steering kit
Computech.com Datamaxx logger LCD dash with all sensors needed
SIKKY Swap kit
SIKKY SWAP KIT
LQ9 from LKQ
wire tuck
More wire tuck
Getting Ready for datamaxx logger LCD dash
Tear down of stock cluster
Volk SF Challanges i picked up from Cliff aka DZ n.u.t.z
Chasebays MIL Spec LSX harness
*UPDATED PICS 3/31/11*
3.5 inch collector on the Sikky 7/8 headers
ARP head studs and 255lph
DGR coilovers thanks Russ!!!! and Assaultech.com
32 way adjustable DGR coilovers
More pics of the DGR coilovers
New wheels
FAST 102mm from www.Chasebays.com
04 Z OH6 MAF
Buddyclub Low down rails From www.Chasebays.com to pair with a status racing seat
IMG]http://i749.photobucket.com/albums/xx132/logandbrewer/image.jpg[/IMG]
T 50 SEX Stage 2 built from www.tick-performance.com
RAWWRRR!!!!!!! Motors in!!!
Chase bays LSX power steering kit and reservoir www.chasebays.com
http://www.youtube.com/watch?v=E2W9t...layer_embedded
First start up VID untuned
http://www.youtube.com/watch?v=puJz9CKfSu0
More untuned footage
http://www.youtube.com/watch?v=ODlB_9HuLjQ
First magnaflow exhaust
http://www.youtube.com/watch?v=-NV6AAumjG8
http://www.youtube.com/watch?v=NWhaR7oxtjI
http://www.youtube.com/watch?v=IyngWy2unaI
New Exhaust videos for you to enjoy ill have some more this after noon in the light. This is still a 3.5 inch exhaust with a Vibrant resonator, and Spin Tech 6000 Pro Street Series muffler. ENJOY!!
Here are some updated shitty iphone 4s pics i took of how the car sits and some of my fav new additions that i love.
Old shifter
New shifter
If you look at the old shifter they have added some brash washers. As Quamen mentioned earlier they had some major play and I'm hoping this will solve that problem.
They have also added brass washers here as well to make up for the play. I hope to get this and my new Mil-Spec harness thrown on tonight and will keep those with the sikky kit updated.
My old harness loomed in the Nylon braided loom- Does not come with a Cannon plug disconnect - What we call a CM1 harness. Goes directly from the motor to the ECU like stock
The Mil-spec harness comes loomed in the Raychem DR25 high heat and diesel fuel resistant heat shrink and individual sensor labeling. It will also come with the Mil-Spec cannon plug quick disconnect
The original harness was only used for mock up and testing. No sense in using the expensive loom ad cannon plug for mocking up and testing
here is a picture of the individual sensor labeling
here is a quick picture i snapped with the iphone while we were taking better pictures with the sweet nikon d5100
http://www.youtube.com/watch?v=5nZD4Pw2wa8
This was open header ^^^^^
http://www.youtube.com/watch?v=CIZn0XUU_ng
Spec 3+ with Aluminum Flywheel, and Spec throwout bearing, off with the spec stock stuff and on with the Sikky quick bleeder and line adapter.
Sorry for the crappy Iphone 4 pics I hope chase from Chasebays or Danny from assaultech will bring one of their nice camera so we can get some better pics for you guys.
If you have any questions let me know
Thanks,
Logan
Strafe Trunk
Motor
LQ9
Custom cam
Trans
New Front Seal
New Rear Seal
Wiring/Fuel
255 lph fuel pump
SIKKY Swap kit
SIKKY SWAP KIT
LQ9 from LKQ
wire tuck
More wire tuck
New wheels
04 Z OH6 MAF
Old shifter
New shifter
Thanks,
Logan
Re: Should a had a V8, Allmotorbrew's LSX Swap 2.0
I was running the stock G35 radiator for the time being with no problems on cooling the LQ9 but wanted to gain some room to play around with piping for a single turbo application. I used a chasebays tucked radiator designed for the g35 LSX swap. This radiator is a dual pass and i ordered mine with both inlets and outlets -16AN.
Since i am still waiting to have a single turbo hot/cold side made up - (waiting in line for the local fab expert) i decided ill put a heavy wet shot on to tide me over. I swapped from the 102mm to the 92mm because i wouldnt loose any HP and i was having a weird idle issue this solved it right away.
I also hated the fact that for HP tuners i had to go back to my tuner to change any little things that i wanted done. So i switched to the Haltech Platnium sport 2000. With the milspec harness that i have it was easy to just pop off the back half of harness that connected to the stock GM ECU and swap it for haltech plugs.
Should have my water pump back from the fab shop first of next week and still waiting on haltech ECU plugs to show up here at the shop
AN fittings are being welded on so i can use one of our duel pass radiators with AN fittings.
at the jetties fishin'
and just in case anyone is doubting the lowly truck engines...
here's an article where hotrod magazine takes a junkyard core truck engine and runs up the boost on it past 1200hp. stock shortblock, off-shelf cam, some head porting, aftermarket intake. thats it. well two big ebay turbos lol.
article talks about it being a 5.3L but if you read to the engine you'll see they realized it was actually a 4.8L
http://www.hotrod.com/techarticles/h...g_bang_theory/
crazy mad murdock
Saw the test and tune vids, what was your best time? And what kind of power are you making?
Yeah...the LSx engines are modular from GM for those that don't know. You can put together a 500hp powerhouse using the iron truck blocks and bits and pieces from other engines for less than the price of a B18c5. These motors are ridiculously capable and super compact. They're not as heavy as people think either. With LS1's getting cheap as ever, you can even have a full aluminum block that is still plenty capable. I'm making 578whp512tq on my LS6 right now and it's as reliable as a 1.6 stock single cam.
To the OP...that swap is REAL nice in that car....good job bro. I didn't happen to catch it though...what actual tranny did you use, T56?
dupes4lyfe
Engine Machining & Assembly
05-05-2018 09:59 PM
SlowVtecCrx
01-04-2005 05:47 AM
TDRacing
06-25-2002 10:38 PM
article, code, dashboard, diesel, finder, honda, motorcycles, performance, powered, reverse, state, transmission, vintage, washington, zip
