Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Required quarts of oil
Old 07-15-2007, 08:23 AM
quilter@atlanticbb.net's Avatar
Default Required quarts of oil
I just changed the oil on my 2007 CRV. The manual says the 2.4 liter engine uses 4.4 quarts but the dip stick registers 1 quart low even after a full 5 quarts of oil. What gives? Do I follow the manual or the dip stick?
Thanks.
Old 07-15-2007, 08:31 AM
hondacivic90zc's Avatar
Default Re: Required quarts of oil (quilter@atlanticbb.net)
me personally i would follow the dipstick
Old 07-15-2007, 09:49 AM
Crx Jimmy's Avatar
Default Re: Required quarts of oil (bossman032)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">your moron ur in the wrong section.
If I were a mod I would ban you one less moron. </TD></TR></TABLE>
Shut up or get out, you can see he is new, he doesnt need the likes of you telling him what to do, if I were a mod I would ban you. Im sure he didnt post here on purpose. You were a noob too at one time, give the guy a break.
To the original poster, make sure your car is perfectly level, even if its on a slight slant the dipstick might read, 1/2 quart off, if its on a larger slant it could read up to a 1qt off. Also make sure the dipstick is going ALL the way back in, sometimes it is also hard to read when the oil is clean. Im sure you have enough oil in it to drive it somewhere flat and wait a couple minutes and check again. Tell us how you make out
Old 07-15-2007, 10:19 AM
Allday07's Avatar
Default Re: Required quarts of oil (Crx Jimmy)
you tell em crx jimmy
Old 07-15-2007, 10:27 AM
Stouts 'n' Scotch
wiZCo's Avatar
My thoughts exactly, except directed towards you. I hope Toad or Vap deduct points from you asshat.
OP, here's the forum you want for your CRV BTW: https://honda-tech.com/zeroforum/80
This is the CRX forum
Old 07-15-2007, 11:12 AM
bossman032's Avatar
Default Re: Required quarts of oil (wiZCo)
you guys are a bunch of retard noobs.
learn how to post in the right place. Big failure rates of you graduating noobs who can't read nor do **** right!
CRX is a CRV LOL!
Old 07-15-2007, 11:13 AM
bossman032's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
To the original poster, make sure your car is perfectly level, even if its on a slight slant the dipstick might read, 1/2 quart off, if its on a larger slant it could read up to a 1qt off. Also make sure the dipstick is going ALL the way back in, sometimes it is also hard to read when the oil is clean. Im sure you have enough oil in it to drive it somewhere flat and wait a couple minutes and check again. Tell us how you make out</TD></TR></TABLE>
WOW NOOB!
at least you know something.
Old 07-16-2007, 07:03 AM
Stouts 'n' Scotch
wiZCo's Avatar
Reported.
Old 07-16-2007, 02:46 PM
diversegsr's Avatar
after you put in the required amount of oil....put oil cap back on and run the engine for about 15-30secs.....the level should be where it needs to be on hte dip stick......if not....add the correct amount and you are good to go
Old 07-19-2007, 05:10 PM
MatterMatt's Avatar
Default Re: Required quarts of oil (diversegsr)
That is correct! Put 4.5 quarts in, and run it then check the level. If you just pour in the oil and pull the dipstick your reading won't ever be right.
Old 07-20-2007, 12:06 AM
bossman032's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">Reported.</TD></TR></TABLE>
LOL Noobs! They never learn your opinions means ****.
ITR0842
03-23-2008 07:21 PM
EK_B
10-28-2007 02:39 PM
motormike40
08-15-2006 08:24 PM
kegard
32
05-30-2005 12:12 AM
-iLLuZioN-B18C1
09-01-2003 05:32 AM
Quick Reply: Required quarts of oil
