Odyssey Build: JDM StyleWagon Content - Page 5 - Honda-Tech
Old 08-27-2011, 07:30 PM   #101
redskull1944's Avatar
Default Re: Odyssey Build: JDM StyleWagon Content
Didn't see a wing today but odysseys always show up at the junkyard
redskull1944 is offline   Reply With Quote
Old 09-01-2011, 03:05 PM   #102
gentek1145's Avatar
THE UPDATE YOU'VE BEEN WAITING FOR...
Still need to cut & buff the front bumper, door caps, side skirts, mirrors, mirror covers, tail gate trim and other misc. items, and reinstall the glass, lights etc...
Ambitionz Auto Salon did an AMAZING paint job on this one. They put in way more hours than originally planned and it looks amazing in person. You can't find a single tape line on the body, because there aren't any. The Lexus 460 Exhaust and the JDM Tail gate look OEM to me, like they were made that way to begin with. The antenna delete, wiper delete, emblem delete all turned out great.
gentek1145 is offline   Reply With Quote
Old 09-04-2011, 03:55 PM   #103
gentek1145's Avatar
Getting it together finally! Just waiting on a few more OEM parts for the exterior.
Old 09-05-2011, 07:15 AM   #104
noeticnormy's Avatar
Looks good man! I know you can't wait.
noeticnormy is offline   Reply With Quote
Old 09-05-2011, 07:35 AM   #105
HT's Biggest Loser
SIXTYdashONE's Avatar
f*kin sck man!
SIXTYdashONE is offline   Reply With Quote
Old 09-08-2011, 08:40 PM   #106
gentek1145's Avatar
New roof moldings & clips installed. These were in stock at vintage Honda
Wiper Arm Cowl has been refurbished back to new. Just waiting on new clips from Honda
Custom Ultra-Bright LED's for the license plate illumination. 6000K Color
Old 09-08-2011, 09:04 PM   #107
Dude how long till we see this thing at a show?
Old 09-09-2011, 02:50 AM   #108
HT's Biggest Loser
SEMA is right around the corner
Old 09-11-2011, 11:51 PM   #109
rodneyk's Avatar
Looking good! can't wait to see the finished product
rodneyk is offline   Reply With Quote
Old 09-13-2011, 10:13 AM   #110
gentek1145's Avatar
New Hood Prop Clip
New Clips & sockets for the wiper cowl trim
New Sway bar bushings front & rear, new brackets and stainless steel hardware
Old worn out:
New:
I plan on changing every bolt on the van eventually with a stainless steel one so it doesn't rust quite as much. It seems the factory washers are the culprit to most of the corrosion. Stainless is a better solution since it doesn't rust.
All of the bolts in the engine bay however are getting a billet aluminum fender washer treatment as well:
Found that a few of the studs on my air struts were stripped / broken so I decided to tear down and replace all of them with grade 8 hardware. Cut / Welded new studs in place. Also refurb'd the top hats and cleaned / lubed the pillow ball mount.
Old 09-13-2011, 10:17 AM   #111
gentek1145's Avatar
While I was in the fenders, decided to gut and strip them down, and reline them with truck bed liner. It's a lot tougher than regular spray-on under coating which can flake off after a couple of years of abuse...I just used a wire brush and brake cleaner to strip and prep the surface. This should be more durable protection, and cut down on road noise as well.
Stripping / wire brushing the fenders
New coating done
Replaced the rusted bolts and hardware for the front suspension, also installed new upper control arms & ball joints
Done!
Old 09-13-2011, 10:37 AM   #112
Nice, you have a timeline on this build?
Old 09-13-2011, 12:28 PM   #113
I just found this build and i had to say that your Odessy is awesome, definitely one of a kind. Your attention to detail is crazy in a good way. The Lexus exhaust is cool as hell.
Wyatt87 is offline   Reply With Quote
Old 09-14-2011, 07:51 PM   #114
goonslude's Avatar
i want your RA1 lol. What motor are you running.
goonslude is offline   Reply With Quote
Old 09-15-2011, 06:08 PM   #115
gentek1145's Avatar
Thanks to my NEW Sponsors for SEMA.....there are some new, bad *** goodies coming for the van
Mishimoto, Password:JDM, Second Skin Audio, Odyssey Battery, NRG Innovations, PowerSlot Brakes
www.mishimoto.com
www.passwordjdm.com
www.secondskinaudio.com
www.odysseybattery.com
www.getnrg.com
www.powerslot.com
The motor is stock F22 right now, future plan to swap in H23 Blue
Old 09-15-2011, 09:52 PM   #116
goonslude's Avatar
ley me know how it goes i am looking on to it and a j35 swap
Old 09-16-2011, 12:04 PM   #117
gentek1145's Avatar
It's already been done, it works fine. H22 / H23 is a direct swap into the 95-98 Odyssey, it's the same as swapping into a 94-97 Accord.
Old 09-16-2011, 12:06 PM   #118
gentek1145's Avatar
rear glass installed
Old carpet out, carpet and padding going in
Old 09-18-2011, 04:24 PM   #119
gentek1145's Avatar
Started to work on pulling the cruise control system out and cleaning up the engine bay a bit. Pulled the stock battery, stock battery tray and a bunch of un-necessary brackets and bolts out. Replaced the battery with an Odyssey High Performance battery, and a Odyssey Billet Aluminum Battery Tray. For a cleaner look, I am transverse-mounting the battery, as opposed to the stock horizontal positioning. All of the bolts in the engine bay are being replaced with Stainless Steel hardware & Billet Aluminum fender washers.
Good bye cruise control & rusty battery tray
After a good cleaning, trimming of the fuse box brackets and moving a few lines around.
Old 09-18-2011, 06:46 PM   #120
Good work man... You have a timeline for this thing to be back on the road?
Old 09-18-2011, 10:12 PM   #121
gentek1145's Avatar
i already said, SEMA.
Old 09-22-2011, 08:58 AM   #122
gentek1145's Avatar
Mishimoto Aluminum Radiator, Aluminum Fan Shroud w/ dual Electric Slim Fans & Blue Silicone Hoses arrived! When it's 110 degrees outside, this is going to be one cool puppy.
These have a no-questions asked, LIFETIME Warranty from Mishimoto; bar none!
Old 09-28-2011, 12:01 PM   #123
gentek1145's Avatar
Things back from Powdercoating...
Rear subframe brace, radiator stay brackets & a/c line bracket. no mo rust' - Bright Silver Powdercoat finish. I think I'll be doing the sway bars and rear suspension arms in this same finish soon.
Finally off back order I was able to get 4 new door trim moldings for the exterior.
Old 09-29-2011, 08:31 AM   #124
WhiteSlips's Avatar
Looks good Jeremy. Can't wait to see what you do with this thing!
WhiteSlips is offline   Reply With Quote
Old 09-29-2011, 12:37 PM   #125
Caretaker's Avatar
your thread makes me want an odyssey now. can't wait to see it done! awesome build
Caretaker is offline   Reply With Quote
NSX on BBS LM's / GT Coolant Tank & New Goodies gentek1145 Acura NSX 17 06-28-2014 07:21 AM
Perfect Daily Driver for sale 1994 Accord EXL VTEC - DALLAS gentek1145 Texas -OK -LA (Sales) 0 02-06-2012 07:00 PM
**** HUGE S2000 PART OUT *** ARC / INGS+1 / CUSCO / WILWOOD / ASM / T1R gentek1145 Texas -OK -LA (Sales) 13 01-23-2012 06:25 PM
/// VANS Thread! Post your Honda Odyssey VANS! /// gentek1145 Group Threads 1 09-05-2011 01:19 PM
Air Runner 5 Gallon Air Tank & Compressor For Sale gentek1145 For Sale 0 02-22-2011 12:10 PM
Tags
2005, 2006, 2008, 95, 98, accord, body, chrome, covers, honda, jdm, kit, kits, mirror, odyssey, parting, spoiler
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
