CRV headlight warning buzzer - Honda-Tech
Old 01-26-2009, 05:34 AM   #1
instructor74's Avatar
Default CRV headlight warning buzzer
Just woundering if anyone has had a problem with there CRVs warning buzzer. 2006 crv headlight warning buzzer just stopped working the other day. I haven't had any time to look at it yet and was checking here to see if anyone had come across this with their crv and had a fix for it? If not I should be tearing into it in the next day or 2 and hope to come p with a fix
instructor74 is offline   Reply With Quote
Old 01-26-2009, 02:08 PM   #2
Default Re: CRV headlight warning buzzer
bump
Old 01-27-2009, 06:18 PM   #3
redej878's Avatar
Does the dome light turn on when you open the driver's door? if not than you need a driver's door switch. Seen this a million times on these crvs.
redej878 is offline   Reply With Quote
Old 01-28-2009, 06:12 AM   #4
In a Junkyard near you.
Ross 2.0's Avatar
Quote:
X2
You can just take the switch out and pop it back together usually.
Ross 2.0 is offline   Reply With Quote
Old 01-28-2009, 06:26 AM   #5
dome light turns on when the driver side door is open. thanks for the input I guess I will have to do a lttle more trouble shooting
Edit: some times I hate newer cars. The damb key flob turns on the dome light parking the car turns on the dome light lock or unlock the car the dome light turns on. Park the car turn it off and sit in it until the domelight goes out open the drivers door and wow the dome light doesn't turn on. Looks like the door switch is bad. Thanka for the info
Old 01-22-2010, 11:56 AM   #6
New User
I believe that you will also find that the door switch not operating will cause the warning sound when the key in left in the ignition to fail. Also, if you use the remote keyless entry fob to open the door, a door switch failure will mean the door opening is not detected by the system and the doors will automatically relock after 30 seconds if the engine is not started in that time frame. This could be a bad thing if you use keyless entry and then toss you books and keys in the car and then close the door to go back into the house to get something else. When you come out, the car will be locked with your keys inside.
tmurphy3 is offline   Reply With Quote
Old 11-18-2013, 03:21 PM   #7
MikesRJ's Avatar
I realize this is a fairly old post, and certainly there a dozen more just like it, but I have a question concerning this issue. My door chime is so low sounding that I think it needs to be replaced. Does anyone have the part number to the chime/warning buzzer part? I tried looking on every parts website I could find and cannot seem to locate the P/N.
MikesRJ is offline   Reply With Quote
Old 02-15-2014, 05:28 AM   #8
Quote:
rugger is offline   Reply With Quote
Old 02-15-2014, 05:37 AM   #9
I have a 2006 CRV and it's doing the same thing and I posted here and nobody answered. I know a honda technician of 15 years and he told me door switch. Only problem is that the dome light still works and I found a suggestion, not in this forum, that said it might be another issue, not door switch because dome light still works. My alarm doesn't work for key in ignition switch when door is open and car is off either. I think they're related. Headlight on alarm doesn't work when key is out and door is open either. With that said, if you'll notice that the common factor is door open and vehicle shut off. I'm replacing door switch, despite the fact dome light still works when door is open and vehicle is shut off.
Old 02-15-2014, 05:39 AM   #10
Good bye forum. Nobody answered my problem so I'm outta here
Special Thanks to Honda Tech Members (DIY Video) Jasonbailey Tech / Misc 0 06-13-2015 08:21 PM
HEADLIGHT BUZZER NOT WORKING WHEN DRIVER DOOR OPEN Meconium Honda Civic (2001 - 2005) 2 03-17-2014 06:15 PM
96-00 Headlight Warning Buzzer ROMOJDM Honda Civic / Del Sol (1992 - 2000) 5 12-22-2012 07:24 PM
wiring fog lights to headlight warning buzzer? pjr710 Honda Civic / Del Sol (1992 - 2000) 4 08-24-2007 06:45 PM
CRX Headlight Buzzer? EBay? Anyone? RacerBoy Honda CRX / EF Civic (1988 - 1991) 15 01-30-2004 06:50 AM
Tags
2001, acura, buzzer, civic, crv, del, dome, headlight, honda, interior, light, short, sol, warning, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
