Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2016 Honda Pilot J35Y6 91 vs 87 Oct
Old 03-01-2017, 12:33 PM
norcalem2's Avatar
Default 2016 Honda Pilot J35Y6 91 vs 87 Oct
My question is if I start using octane will I get more power or the same power of the MDX? Since J35Y6 is the same motor in the Acura TLX and Acura MDX? If you see the compression ratio it the same 11.5:1
Also is the ECU smart enough to recognized the difference between 87 to 91 octane?
Basically if I start using 91 octane am I just throwing money away?
J35Y5
- Variable Cylinder Management
  • 2014+ Acura MDX
  • Displacement: 3,471 cc (211.8 cu in)
  • Bore and stroke: 89 mm (3.5 in) x 93 mm (3.7 in)
  • Compression: 11.5:1
  • Power: 290 hp (217 kW) @ 6,200 rpm
  • Torque: 267 lb·ft (369 N·m) @ 4,500 rpm
  • Valvetrain: 24v SOHC VTEC (VTEC on intake and exhaust valves)
  • Red Line: 6,800 rpm
  • Fuel cutoff: 7,200 rpm
  • Induction/Fuel Delivery: Naturally Aspirated - Direct Injection
J35Y6 - Variable Cylinder Management
  • 2015 Acura TLX
  • 2016 Honda Pilot
  • Power: 290 hp (217 kW) @ 6,200 rpm (Honda Pilot 280 hp (209 kW) @ 6,000 rpm)
  • Torque: 267 lb·ft (369 N·m) @ 4,500 rpm (Honda Pilot 262 lb·ft (355 N·m) @ 4,700 rpm)
DarkRattle
07-12-2017 02:58 AM
EgHatchy96
13
09-30-2013 03:43 PM
2k.civic.si
28
01-04-2011 02:48 AM
dohcMONSTER
12
04-01-2006 08:24 AM
DJ_CARY
61
08-25-2004 06:28 PM
Quick Reply: 2016 Honda Pilot J35Y6 91 vs 87 Oct
