Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2009 Honda Pilot - SRS code 1-1
Old 06-15-2016, 08:10 PM
weatherall123's Avatar
Default 2009 Honda Pilot - SRS code 1-1
I have a 2009 Honda Pilot with a recent SRS light. Pulled the codes and came up with 1-1, open circuited Or high resistance in driver's airbag inflator. According to the FSM, the problem could be a poor connection anywhere between the airbag and the SRS control module.
I started with the clock spring. The pilot's clock spring has four wires that go to the air bag. I tested for continuity between each of the clock spring's wires. Three wires had continuity, and the fourth (black) wire did not. Can I assume, by using this test, that the clock spring is faulty? Should all four wires have continuity? Does anyone have a wiring diagram for the airbag/clock spring?
Thanks in advance!
dharrold
12-16-2013 01:50 PM
96civic909
09-11-2012 06:06 PM
KlownBoBo
11-09-2008 01:24 PM
integraboy22
07-07-2007 11:33 AM
undercoversi
10-27-2004 03:35 PM
Quick Reply: 2009 Honda Pilot - SRS code 1-1
