Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2006 Ridgeline intermittent immobilizer
Old 06-29-2015, 10:17 AM
kaz norvaisas's Avatar
Default 2006 Ridgeline intermittent immobilizer
The immobilizer on my 06 ridgeline will work for 1 or 2 months then not start for a week without many attempts or so then months will go by OK
Fuel pump relay has been changed.
can I remove the ECU wire to the pump relay and connect it to + or -
to make it start so the pump runs when the ignition is on.
Beautiful truck otherwise
Kaz
Old 06-30-2015, 03:41 AM
speedlever's Avatar
Default Re: 2006 Ridgeline intermittent immobilizer
Are you positive it's the immobilizer? I'd suggest you check/replace the starter cut relay and see if that resolves the issue.
berdo94da
06-27-2008 11:47 PM
JDMB20TDA
08-18-2007 08:45 AM
integrapunk67
02-03-2007 09:51 PM
pprowler6
12-26-2005 09:53 AM
-DC2-
08-04-2003 09:58 AM
Quick Reply: 2006 Ridgeline intermittent immobilizer
