2006 Odyssey Rear Rotor Removal Question - Honda-Tech
Old 05-16-2011, 12:10 PM   #1
Default 2006 Odyssey Rear Rotor Removal Question
Please advise what I have to do to remove the rear rotor on my 2006 Odyssey.
I have removed the caliper and retaining screws on the rotor but it seems to be hanging up, maybe on the emergency brake shoes. The emergency brake is fully released and I can move the rotor out from the flange but it seems to be hung up and I don't want to force it without knowing if it's just the shoes catching on the ridge inside the rotor or if I need to adjust the shoes to allow it to be removed...
If it needs adjusting, how is that done?
Thanks for your help...Jim
ajs08648 is offline   Reply With Quote
Old 05-19-2011, 09:50 AM   #2
Default Re: 2006 Odyssey Rear Rotor Removal Question
Spin and pull at the same time. If the shoes are catching on the lip of the drum, you may need to take out the rubber plug and loosen the shoes first.
DChan415 is offline   Reply With Quote
Rear Drum Brakes Koko4 Honda Civic / Del Sol (1992 - 2000) 15 09-16-2013 07:17 AM
rear brakes not working after shoe replacement buddy190 Honda Civic / Del Sol (1992 - 2000) 8 04-10-2009 11:11 PM
drum brakes draging pos_cd5 Honda Accord (1990 - 2002) 23 06-11-2007 06:24 PM
Rear Brake Drum Removal - 96 Civic - having trouble sdanville Honda Civic / Del Sol (1992 - 2000) 7 07-31-2005 05:10 PM
How To: Rear Drum brakes shoe replacement StimpyBoy Honda Accord (1990 - 2002) 1 04-25-2004 06:32 PM
Tags
2006, brake, caliper, change, honda, odyssey, parking, pilot, rear, release, removal, remove, replace, rotor, rotors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
