Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2006 Honda Odyssey EX-L AC Problems
Old 09-04-2015, 04:58 PM
humphrey1989's Avatar
Default 2006 Honda Odyssey EX-L AC Problems
Hi. New here. Looking for assistance for my grandmothers Odyssey.
Problem is that the front AC doesn't blow air very hard.
Rear air blows really good. Moves a lot of air.
Cabin/Outside selector doesn't change the flow of air.
I can hear the blower motor in the dash when the air is on.
Tested resistor.
Part 1 -How to Test the Blower Motor Power Transistor (2001-2007 Honda Civic)
Pin 3/4 provide 1500 ohm.
Diode test on pins 2/4 provide a reading of 445.
This was with the red on 2 and black on 4.
When I swap those, red on 4 and black on 2, I get no change or the number 1.
Old 09-15-2015, 02:24 PM
SirFerret's Avatar
Default Re: 2006 Honda Odyssey EX-L AC Problems
Make sure to check the relay that controls the AC compressor clutch. That relay and also the AC condenser fan relay are know to fail and cause AC problems. I had this happen in my 08' Odyssey, after confirming it was a bad relay, I just picked up the part from my local dealer for about 20 bucks, but they can be had online for cheaper if you can wait on it.
Old 09-16-2015, 03:37 PM
Thanks for the "speedy" reply.
I have already solved the problem.
ryanb14
Honda CR-V & Element
07-23-2022 10:59 AM
AshleyBullard
07-27-2017 01:42 PM
PhilC03
Honda Civic (2001 - 2005)
10
06-10-2012 07:17 PM
Civic Racer X 7
08-23-2007 08:42 AM
Quick Reply: 2006 Honda Odyssey EX-L AC Problems
