2005 Pilot Catalytic Converter Change - Honda-Tech
Old 01-28-2011, 08:39 PM   #1
Icon6 2005 Pilot Catalytic Converter Change
From what I can find so far, it appears that the front and rear catalytic converters (the two attached to the engine) are bolted on. So, all I need to do is unplug and remove the oxygen sensors, unbolt the top and bottom of the converters, remove them, replace the old gasket, and bolt the new converters back on.
Correct?
Do I need to remove the exhaust pipes to get to the rear converter? Trying to get rid of the 420 and 430 codes............ugh.
Any step by step help from anyone familiar with this process on the '05 Pilot would be awesome. Please help.
Thanks.
safety1910 is offline   Reply With Quote
Old 01-30-2011, 09:13 AM   #2
Default Re: 2005 Pilot Catalytic Converter Change
C'mon......someone must have the genius to answer this question..........
I am clueless here..............the funny thing about this is, if I do not get my 0420 code to go away by Feb 2011 the wonderdul state of Rhode Island is going to take away my license...........ITS A FREAKIN 0420 CODE!!!! THEY NEVER GO AWAY!!!!! Money machine in Rhode Island. UGH.
HELP!!!!!!!
Old 01-30-2011, 09:36 AM   #3
90sedan's Avatar
Yes, basically all you need to do is unbolt the cat from the head and exhaust and unplug the o2 sensor, however, it's not quite that simple to do it.
To remove the front cat you will need to remove the condenser fan shroud for enough clearance. Then unplug the o2 sensor and then unbolt the cat. The rear cat will require that the axle comes out, because you will need to remove it by taking it down underneath the engine.
Good luck.
90sedan is offline   Reply With Quote
Old 01-30-2011, 02:29 PM   #4
That sucks....
1991 CRX HF cat converter need help Trenton Jardine Honda CRX / EF Civic (1988 - 1991) 4 10-14-2016 02:27 PM
WTB: EG catalytic converter drzxc1usive Want to Buy 2 09-16-2011 02:45 PM
ECU Code P0420 DaleW Tech / Misc 10 06-20-2011 04:10 AM
Is the catalytic converter really needed? fromthesun_93 Honda Civic / Del Sol (1992 - 2000) 9 05-01-2011 07:36 AM
2001 Odyssey catalytic conveter caitengl Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 15 10-02-2009 07:24 AM
Tags
05, 2005, accord, catalytic, change, converter, find, honda, long, pilot, put, rear, removal, ridgeline, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
