2003 Pilot Idle Surge Hell (P0505) - Honda-Tech
Old 11-29-2011, 12:56 PM   #1
Default 2003 Pilot Idle Surge Hell (P0505)
So I've searched the web (and then some), racked my brain, and have tested the **** out of everything I can think of to solve an idle surge.
Vehicle: 2003 Honda Pilot
Symptoms: When the car warms up (NOTE: This car does NOT have a fast idle valve, just an IAC valve) the engine revs up and down from 1000 to 1800ish rpm endlessly. It sets a code (P0505, idle air control system malfunction).
What I've tried/looked at:
I have tested the TPS sensor voltage. .45 volts closed/4.5 WOT. All in spec. I've even replaced the TPS (yes I adjusted it correctly) with same results.
I replaced the IAC valve itself. It got "better" as in when I replaced the valve I reconnected the battery and waited 5 minutes with engine idling to learn the idle (referred to in Honda land as the idle learn procedure). The rub here is the car idle freaking perfect (650-700rpm) right after this, but the minute I pull it out of the garage and go for a 2 minute drive, wamm...back to surge land.
So here are my next thoughts:
I've sprayed a metric ton of throttle body cleaner looking for vac leaks. None found (yet). I put my finger over the IAC-V hole in the throttle body. The idle settled down but did not kill the engine (NOTE: I only used my finger which isn't the best seal of course).
I am planning on:
Bleeding cooling system (in my opinion it shouldn't affect this as the coolant to the single IAC valve is only for heating purposes/read: no wax pellet fiav type crap) as I read several articles pointing to that being a possible coolant temp sensor nightmare resulting in this.
Putting a nice thick piece of duct tape over the iac-v hole to see if the engine will stall out (thinking vac leak test). Of course I could/will try to put my hand over the throttle body itself as this SHOULD kill the engine assuming no vac leaks.
Full disclosure: I had this POS car at the dealer a few weeks ago for diagnosis of an SRS system issue (entire ****ing srs computer that I replace for $90 versus the $699 the dealer wanted of course) and they "diagnosed" the idle issue as "Saw TPS voltage high, internal failure of throttle body recommend replacement". This is puzzling as I stated that I measured the tps voltage at idle and it was the correct .45 volts. Is it POSSIBLE that the throttle body itself is not closing 100% of the way? Visually it looks "ok", however I figure if the iac-v hole with tape test doesn't stall the engine that I could try spraying right into the throttle body blade itself to see if anything gets past it when theoretically closed.
ANYONE who can provide assistance is seriously appreciated.
freudie1 is offline   Reply With Quote
Old 11-29-2011, 02:10 PM   #2
Default Re: 2003 Pilot Idle Surge Hell (P0505)
UPDATE: I bled the cooling system (no air, but hey I ruled it out).
I put my hand over the throttle body itself. Car stalls. No vac leak after TB I would say!
I then completely sealed the IAC-v hole before the throttle blade with duct tape. Car idles perfect. I then sprayed throttle body cleaner at the closed throttle blade (while iac-v hole was sealed closed). Car stalls. Possible issue with throttle body valve itself!?! I'm not sure how "sealed" a closed Honda TB is supposed to be.
Anyone? I'm left with:
Bad throttle body itself/replace the whole TB
Or
Bad IAC valve from Autozone
Thoughts!?
Old 11-29-2011, 02:37 PM   #3
Just for a final test:
I checked TPS during issue/surging. TPS voltage is rock solid .50 volts before and during issue (which is acceptable).
Bad IAC or bad TB itself? Anyone?
A POSSIBLE scenario is a bad sensor elsewhere in the car commanding the IAC-V to go nuts. The only one I can think of is the coolant temp sensor in the bottom of the radiator itself. I had an issue with that one (keeping key-off fan on forever), but that doesn't happen anymore. Is that sensor part of the idle equation?
P0505 code + high/fluctuating idle bdonahue Honda Accord (1990 - 2002) 3 03-21-2016 09:20 AM
Idle Issues? Read This! Ohmega Honda Civic / Del Sol (1992 - 2000) 3 11-22-2015 10:33 PM
99 Accord - IACV - surging pulsing idle at op temp gavman Honda Accord (1990 - 2002) 2 12-12-2011 09:35 AM
TPS and IACV hondastrtracr Honda Prelude 3 05-01-2006 10:10 PM
Idel surges w/ IAC but fine w/o IAC ??? ranta18 Honda Prelude 25 01-29-2005 08:43 PM
Tags
03, 06, acura, adjustment, body, hand, honda, iac, idle, location, mdx, p0505, pilot, revs, stalls, surge, surging, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
