Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2003 Odyssey idle surging P0505 P01129
Old 01-21-2009, 04:37 PM
rasta420's Avatar
Icon6 2003 Odyssey idle surging P0505 P01129
My friend has a 2003 Honda Odyssey. I checked the codes today and P0505 and P1129 came up. The check engine light and TCS lights were on, and the idle was surging up and down at idle.
Is this a common problem or is there a TSB on this issue? What should I check/replace?
Thanks!
Old 01-21-2009, 05:48 PM
In a Junkyard near you.
Ross 2.0's Avatar
Default Re: 2003 Odyssey idle surging P0505 P01129
Clean or replace the IAC valve and clear the codes. Very common issue.
For the heck of it check the power steering switch wires at the bottom passengers side of the engine bay too.
Old 01-23-2009, 03:46 AM
rasta420's Avatar
I took off the IAC valve and reset the check engine light last night. Upon first start, the engine was idling fine for about a minute then started hunting up and down again.
Would replacing the IAC valve fix this hunting idle problem? How can I test the old one to make sure it is faulty?
What am I looking for as far as the power steering switch wires? If they are disconnected? What would that have to do with the problem?
Old 01-23-2009, 05:08 AM
Ross 2.0's Avatar
You'll need to replace the IAC then.
If the wires are broken the van will idle up and down but more randomly.
Old 09-28-2009, 01:48 PM
New User
gregg886's Avatar
What size socket or wrench is needed for the one bolt?
Old 08-04-2010, 02:59 PM
MiniVanDad's Avatar
I need to either clean or replace my IACV... but I can't find it.
Can you post a pic of where it is? I have taken pitcures of my van and you can view them here... http://picasaweb.google.com/Iamtheitguy/VanOdyssey2002
Old 08-04-2010, 04:18 PM
bryse68's Avatar
the IAC valve is located under the throttle body. check for broken power steering pressure switch wires....
Old 08-04-2010, 04:30 PM
MiniVanDad's Avatar
yeah I found it, but since it is upside down to me I don't have what it takes to get it off... but where are the power steering wires you mentioned?
Old 08-05-2010, 05:10 AM
NDNV's Avatar
The power steering pressure switch can be accessed behind the passenger's front wheel. If one of the 2 wires are broken, you can get an erratic idle while stopped. Check the connector and the wires. Here are some pictures of the PS connector:
http://www.odyclub.com/forums/attach...&postid=291641 the harness is disconnected here.
http://www.odyclub.com/forums/attach...&postid=349850 one of the wires are broken here.
mannyquestions9
04-11-2018 06:37 AM
671islander
08-29-2009 04:27 PM
91highryda
09-26-2007 04:58 PM
Victor
12-01-2004 10:29 AM
Blkteg97
11-03-2004 08:49 PM
Quick Reply: 2003 Odyssey idle surging P0505 P01129
