2002 CRV Code PO420 - Honda-Tech
2002 CRV Code PO420
Old 06-18-2008, 06:26 PM   #1
neckman's Avatar
Default 2002 CRV Code PO420
My 02 CRV check engine came on with PO420 code. I replaced upstream 02 sensor with Honda OEM part about a year ago. I have noticed a decrease in mileage and sometimes engine feels as though it is holding back. If I reset light it may stay off for days or it may come back soon. Any ideas?
neckman is offline   Reply With Quote
Old 06-29-2008, 05:50 PM   #2
abusedhusband's Avatar
Default Re: 2002 CRV Code PO420 (neckman)
how many miles are on the crv. why did you change a ho2 sensor for the p0420 code? was the sensor not working? are you still getting the engine kight on for the p0420 code?
abusedhusband is offline   Reply With Quote
Old 07-02-2008, 04:08 PM   #3
high_revs's Avatar
your cat is shot. sucks, those things are expensive.
high_revs is offline   Reply With Quote
Old 07-02-2008, 06:06 PM   #4
Default Re: (high_revs)
the cat could still be good. that p0420 code can be tricky. especially on a honda. i very rarely see a honda cat go bad. 90% of the time you can get away with a top engine cleaning.
Old 07-03-2008, 03:52 PM   #5
high_revs's Avatar
from 90% of p0420's i've seen only oem honda cat will take care of that... honda cats go bad more often then you think...we see 4-5 a week at my dealer.
Old 07-05-2008, 05:12 PM   #6
It Wasn't Me!
someone else's Avatar
Default Re: (abusedhusband)
Quote:
I disagree. In the last 5+ years I've been at Honda I would say that the majority of P0420 codes are a failed catalytic converter. The 420 code implies that the O2 sensor is reading correctly. Otherwise you get a O2 sensor code.
someone else is offline   Reply With Quote
Old 07-06-2008, 02:20 PM   #7
high_revs's Avatar
and when a o2 sensor is bad you will 95% of the times get an o2 HEATER code.
Old 07-06-2008, 06:28 PM   #8
im not saying that the o2 is bad, however i have seen a lazy 02 give a false reading and set a p0420. But before i replace any converter i do a justice brothers injectoin service. For a cat to go bad something is wrong, they dont go bad unless poisoned by fuel, coolant, or oil. Some times carbon buildup causes cylinder temps to rise and throws the 02s off and the ecu knows the cat is not efficient enough for the reading its getting. The converter can be shot also. Without any diagnostic time on the vehichle all i can do is make suggestions.
Old 07-09-2008, 04:05 PM   #9
phootbag's Avatar
Secondary O2 sensor input monitors the performance of the catalytic converter. I have seen plastic bags land on the sensor ( located downstream of the cat under the vehicle ) and block the atmosphere vent on the sensor. I have also seen undercoating sprayed on it. I have seen asphalt coat them as well. If you can confirm the secondary O2 sensor is reacting normally then you should replace the catalytic converter. Only use a Honda part. Aftermarket is not recommended.
A primary O2 is not responsible for a p0420.
phootbag is offline   Reply With Quote
Old 07-09-2008, 04:06 PM   #10
phootbag's Avatar
Default Re: (phootbag)
By the way, catalytic converters go bad from normal use. No engine runs clean enough to not ruin a cat eventually.
Old 07-14-2008, 12:39 PM   #11
1SloNeon's Avatar
Just an FYI....I recently got this code a couple of times in my 99 Si. I would clear the code and it would come back a couple of ignition cycles later. I had many people telling me the cat was bad which wasnt the case at all. My car does have an aftermarket cat on it (Random Technologies) which is only a year old or so. I hooked the car up to a scanner only to see the O2 sensor in the cat itself was a little sluggish when starting the car. It wouldnt read right away. I replaced the sensor with an oem one and cleared the code and no check engine light anymore. Just giving my .02 from recent personal experience with the dreaded P0420 code, lol. Good luck!!
1SloNeon is offline   Reply With Quote
Old 08-07-2008, 10:30 AM   #12
shaggyeg6si's Avatar
Default Re: 2002 CRV Code PO420 (1SloNeon)
just put an o2 extender in on the secondary o2 sensor. Done.
shaggyeg6si is offline   Reply With Quote
Help please. I got engine code po430 and po420. HondaMax00 Tech / Misc 4 01-14-2017 01:26 AM
Error Code PO420 2003 Civic EX purenathan Honda Civic (2001 - 2005) 3 10-29-2015 05:19 PM
1998 accord ex po740, po135 sammybananas Honda Accord (1990 - 2002) 2 02-19-2013 11:45 AM
Honda 2002 Accord Lx scorpiontank Honda Accord (1990 - 2002) 4 09-25-2011 08:58 AM
Engine Code Po420 AlwayzSpoolin Acura Integra 1 03-18-2007 08:56 PM
Tags
2002, 2003, 420, check, civic, code, crv, engine, extender, honda, location, o2, p0420, po420, primary, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
