2000 Honda Odyssey surging at idle P0336 - Honda-Tech
Old 08-13-2010, 06:54 PM   #1
Default 2000 Honda Odyssey surging at idle P0336
Hello,
I changed the timing belt on my Odyssey. The problem began when I went to start the engine after install. At idle the engine revs between 1.5 and 2.5 rpms. Checked timing marks and all reference marks were aligned. Also the check engine light came on with a P0336 code. I have removed the alternator and the battery and they both bench tested fine. Took the van on a little test run down the road and it actually stabilized at 1000 rpm and then when I drove about a 1/4 of a mile, the engine started surging again. Checked all the connectors that I removed and everything appears to be o.k. I haven't taken everything back apart to check the CKP sensor yet, was hoping somebody would have a better idea of what to check before I tore everything apart again. Also I checked the p.s. sensor wiring everything ok there to. I am at a lose for what to do next. Any ideas or helpful hints?
Thanks
Honda81 is offline   Reply With Quote
Old 08-30-2010, 10:59 PM   #2
Default Re: 2000 Honda Odyssey surging at idle P0336
My "01 Odyssey did that when we bought it. Started putting super unleaded gas in it and haven't had any problems sense the first tank.
KillerNelson80 is offline   Reply With Quote
Old 08-31-2010, 05:35 AM   #3
NDNV's Avatar
Check the connection for the crankshaft position (CKP) sensor at the oil pump. May have disconnected during the timing belt service. Otherwise, a short or bad ground in this circuit.
NDNV is offline   Reply With Quote
Accord surging/pulsing idle before warmed up Uncle Ben 1 Tech / Misc 3 12-01-2015 12:41 PM
2001 civic will crank but won't start sheeliboy Honda Civic (2001 - 2005) 6 03-22-2015 02:28 PM
OK, Here's a Challenge, 02 Honda Civic Atriticuss Honda Civic (2001 - 2005) 11 09-21-2014 07:34 PM
Idle surging after obd1 conversion dohc4life Honda CRX / EF Civic (1988 - 1991) 1 04-07-2011 05:22 AM
2003 Odyssey idle surging P0505 P01129 rasta420 Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 8 08-05-2010 06:10 AM
Tags
2000, 2005, belt, code, honda, idle, idler, idling, motor, odyssey, p0336, pilot, prelude, problems, surging, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
