1998 Odyssey Misfire only on COLD start up - Honda-Tech
Old 02-17-2010, 08:42 PM   #1
New User
Default 1998 Odyssey Misfire only on COLD start up
Hi Ihave a 98 Odyssey 2.3Lwith 223k miles, on cold start up the engine misfires a lil bit for a few seconds then goes away, doesn't affect driveability, sometimes it will trigger the check engine light and P0302, and P01399 are the only codes, I've already replced all the plugs wires and cap-it was an everyday problem, now it's intermitent. Any thoughts be much appreciated
SD98ODY is offline   Reply With Quote
Old 03-05-2010, 09:01 PM   #2
New User
Default Re: 1998 Odyssey Misfire only on COLD start up
Ok, I found oil inside the distributor cap, the oil would build up at the bottom affecting spark getting to cylinder#2. I replaced the distributor assembly, everything was fine for a couple of weeks and I'm now back to the same problem, momentarally misfiring on cold start up. I might try adjusting the distributor a lil bit??
Old 03-06-2010, 03:40 PM   #3
In a Junkyard near you.
Ross 2.0's Avatar
I JUST had a bout with this on an Accord today. I would like to know what the fuel pressure is and what state you live in.
It's probably low fuel pressure though.
Ross 2.0 is offline   Reply With Quote
03 Odyssey EX-L Misfiring. Only vehicle and Very tight budget audi_nicoya209 Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 4 09-14-2016 02:22 PM
2005 Odyssey EX-L All Cylinders Misfiring Drew082 Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 12 04-30-2016 06:16 AM
00 odyssey starts up fine, then dies right away on hot days myEGthatGo Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 1 01-12-2011 01:48 PM
Misfiring when cold> HELP SOHC_civic_si Honda Civic / Del Sol (1992 - 2000) 14 02-08-2010 12:21 PM
Engine misfire (b16) on cold start ekhonda87 Honda Civic / Del Sol (1992 - 2000) 2 10-22-2008 04:15 PM
Tags
2001, 2008, 98, civic, code, cold, crv, honda, misfire, misfires, missfire, odyssey, p01399, rsx, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
