For Rental: Tool to Extra rear trailing arm bushing!
For Rental: Tool to Extract rear trailing arm bushing!
BROKEN
·Easily and quickly remove and install trailing arm bushings in 15 minutes per side versus the factory "book" time of 1.8 hours per side.
·No removing the trailing arm from the vehicle and using a hydraulic press.
·No need to disconnect brake parts such as calipers, rotors, brake shoes, brake fluid lines and emergency brake cables.
Works on:
Honda; Civic 1988-2000, CRX 1988-1991, Del Sol 1993-1997
Acura; Integra 1994-2001
Also works for DA 1990-1993 Integra as ikona personally tested.
Modified by bluesaint at 5:16 AM 9/15/2006
Modified by bluesaint at 5:17 PM 10/4/2006
Modified by bluesaint at 7:12 PM 9/10/2007
Works on:
Re: (iHATEspeedbumps.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iHATEspeedbumps. »</TD></TR><TR><TD CLASS="quote">i needa one of these last summer. kool tool.</TD></TR></TABLE>
hey did u install the f22c block yet?
Re: (bluesaint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluesaint »</TD></TR><TR><TD CLASS="quote">hey did u install the f22c block yet?</TD></TR></TABLE>
yea i got the block in already. thanks again.
bluesaint is a stand up guy, and the tool works great. i really appreciate it!! +1 for you.
works even better if you freeze your new bushings for like 2 weeks. they almost slide in!
Re: (iakona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona »</TD></TR><TR><TD CLASS="quote">bluesaint is a stand up guy, and the tool works great. i really appreciate it!! +1 for you.
works even better if you freeze your new bushings for like 2 weeks. they almost slide in!</TD></TR></TABLE>
Re: For Rental: Tool to Extra rear trailing arm bushing! (andrew dc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrew dc »</TD></TR><TR><TD CLASS="quote">really cool tool!</TD></TR></TABLE>
forgot who makes it. but it costs $190-200 to buy this tool shipped. So unless you gonna be changing RTA bushings a lot, not a good investment
