FS integra & civic parts, Location Sac - Honda-Tech
Old 03-07-2017, 05:06 PM   #1
siblue_gzer's Avatar
Default FS integra & civic parts, Location Sac
Located in Sac.
Civic and integra parts for sale for cheap. ONLY $20 EACH for #1-48!!! Other parts on the bottom will be priced as listed. Will ship too if u got paypal and pay for shipping.
Miscellaneous parts:
1.ground control hat + sleeve bushings
2.polished shift ****
3.drag caps (fit slipstreams, etc.)
4.d series shifter and ****
96-00 civic parts:
5.passenger axle
6.stock springs
7.evap charcoal canister
8.clutch slave cylinder
9.hid 6k (one bad bulb)
10.ac bracket
11.alternator
12.stock header
13.idle air control valve iacv
14.d16y8 injectors
15.d16y8 throttle body
16.power door lock kit
94-01 integra parts:
17.stock flywheel
18.o2 sensor
19.stock park plug wires
20.clutch master cylinder
21.s2000 look antenna
22.fuel pump
23.tan sum visors
24.fuel rail
25.clock
26.climate control
27.battery tray + holder
28.air bags + unit
29.green hood (flawless)
30.tan dash
31.hood latch, cable + lever
32.cluster + trim
33.stock jack
34.coin tray, cig lighter, cup holder, shift boot
35.spare tire
36.cruise control, unit and switch
37.rear speakers + brackets, front soundstream speakers 6.5 inch
38.clutch slave cylinder
39.ac bracket
40.power mirrors + covers
41.evap charcoal canister
42.coolant reservoir
43.signal + wiper switch, cruise + dimmer
44.trunk lock actuator
45.tan center console + arm rest
46.throttle body
47.bumper metal bracket + fender brackets
48.both fans
Other parts:
-2000 integra LS complete car harness from ecu to headlights, sunroof, floor harness, to the back tail lights $100
-P06 ecu $40
-p2e ecu $40
-dc/eg complete front & rear sway bar conversion $150
-b series motor mounts $40
-integra abs unit, proportion valve & abs sensors $60
-96-98 civic y8 obd2a dizzy $40
-99-00 civic y8 obd2b dizzy $40
-integra complete ac & heater system with blower motor, lines, heater core, evaporator, and ac compressor $100
-ignition, key, immobilizer and ecu $100
-integra LS head $80
-d series vtec valve cover, fits z6 y5 y7 and y8 $40
-14 inch donks, 2 good tires 2 bad tires $80
-clean ek hatch tail lights $50
siblue_gzer is offline   Reply With Quote
Old 03-08-2017, 05:52 PM   #2
Default Re: FS integra & civic parts, Location Sac
Bump
Old 03-08-2017, 06:29 PM   #3
CarGuy75's Avatar
Spare tire Jack & tool bag price shipped to 29385 please.
CarGuy75 is offline   Reply With Quote
J series Insight Build ChokeOnMySmoke Drag Racing 87 03-27-2017 10:00 AM
**RARE** JDM 1990 Honda Civic RT-X Troy Papp Mid-West (Sales) 9 03-09-2017 04:43 AM
EXEDY Clutch Disc HCD040U for Honda Accord dayaftertomorrow33 For Sale 1 02-21-2017 10:08 PM
new car 1985 crx hf hamtrow Introduce Yourself 0 02-21-2017 06:38 PM
Intro for the EJ6.. Vuuuuuuuuuuureeeeeeehhhhhhh :D BahrEJ6 Introduce Yourself 3 12-13-2014 01:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
