FS: 1997 Acura Integra GSR-HPDE / Autocross
Old 03-16-2015, 05:42 AM
GSR_FTW's Avatar
Default FS: $4900 1997 Acura Integra GSR-HPDE / Autocross FINAL price drop
Miles: 150,400
Price: $4,900
I’m selling this 1997 Acura Integra GSR. This was a project that started last year with a clean, numbers matching, 2 owner Integra GSR that I decided to lightly modify for use in HPDE and Autocross. I built this car over this winter, and it has no track days on it yet. This car has been garaged and is not a daily driver (only driven on sunny weekends and occasionally to work where it is also garaged), so it has had less than 100 miles on over $5K in performance parts. In addition, I have done about $2K in maintenance items in the last year as well.
See below for list of modifications/work done recently. This car has been impeccably maintained and is absolutely turnkey. I have ALL original OEM parts so this car can be put back to stock if you so desire. I have a binder full of receipts and maintenance records.
The only negatives on this car is a few small holes in the back seat, a small dent on the back driver-side corner, and general door dings and light scratches consistent with an 18 year old car. Mechanically, this car is in fantastic condition.
I am moving across the country and decided that this car should stay in California, so my loss is your gain. Clean smog cert in hand from 1/9/2015 and this is registered through 2/2016.
Clean title, clean autocheck, no stories, no BS.
Major Modifications/Repairs:
Install AEM Cold Air Intake (AEM 21-404C) $250
Installed Skunk2 short shifter and weighted shift **** $165
Installed Tanabe Medallion Touring T70002 cat-back exhaust $575
Replaced Exhaust Manifold with DC Sports 4-2-1 CARB Header $350
Replaced Catback exhaust with Tanabe Medallion Touring $575
Replaced both O2 Sensors, Denso, OEM $130
Replaced Catalytic Converter- Walker CalCat CARB $270
Installed Koni Sport/Ground Control Coilovers/Tophats: 430lb f/ 545lb r $1,155
Installed ASR Subframe Brace and 24mm Sway Bar $389
Installed Skunk2 rear camber kit $170
Installed Spoon Sports Front Strut Bar $205
Delete Rear Wiper $15
Installed Spoon Sports Rear Strut Bar $180
Deleted Air Conditioning System & installed body plug $10
Deleted Washer Fluid System $0
Deleted Cruise Control System & installed body plug $10
Installed Skunk 2 Pro+ Series Front Camber Kit 516-05-5675 $220
Installed Mugen Pedal Covers $185
Installed Function 7 rear control arms $235
Replaced cam plug, valve cover gasket, oil pan, oil pan gasket, axle seals $220
Replaced thermostat and serviced cooling system $30
Replaced rear taillight gaskets with OEM parts $50
2 new acura oem replacement keys and new alarm remotes $40
Replaced brake master cylinder $300
Replaced all four brake calipers with OEM parts $300
Installed Stoptech stainless steel brake lines $50
Installed Hawk HPS brake pads $50
Replaced clutch master cylinder and slave cylinder $190
Replaced distributor, plugs, wires, cap, rotor $300
Replaced fuel filter, PCV valve, VTEC solenoid gasket $43
Replaced SRS control module $120
GSR_FTW is offline
Old 03-18-2015, 02:14 PM
GSR_FTW's Avatar
Default Re: FS: 1997 Acura Integra GSR-HPDE / Autocross
Bump
GSR_FTW is offline
Old 03-20-2015, 06:36 AM
GSR_FTW's Avatar
Reduced price $1,000 for a quick sale
GSR_FTW is offline
Old 03-20-2015, 08:29 PM
bobmugen's Avatar
nvm saw your other thread. gl with sale
bobmugen is offline
Old 03-22-2015, 11:33 AM
Danger's Avatar
If you wouldnt mind parting with those spoon strut bars they would be going to a good home lol, regardless good luck with the sale.
Danger is offline
Old 03-22-2015, 02:29 PM
supersilverdc2's Avatar
TTT clean car
supersilverdc2 is offline
Old 03-25-2015, 07:29 AM
GSR_FTW's Avatar
I may part it out. I am going to list the car on Craigslist for a week and if it doesn't sell, I will begin to part put.
GSR_FTW is offline
Old 03-27-2015, 11:59 AM
GSR_FTW's Avatar
bum for final price drop $4900
GSR_FTW is offline
Old 03-27-2015, 07:13 PM
Danger's Avatar
Right on, hope you sell the car.
Danger is offline
GSR_FTW
03-27-2015 11:56 AM
cquence
Northwest (Sales)
20
08-14-2011 12:54 PM
AznPrideYo
Southeast (Sales)
28
01-26-2008 09:45 AM
stupidwhitecat
08-21-2007 06:53 PM
nfn15037
11-23-2006 06:33 AM
Quick Reply: FS: 1997 Acura Integra GSR-HPDE / Autocross
