S2k cluster FS. Lowball me!
SOLD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!
Hey H-T. I got this s2k cluster off a friend of mine. He had it in his 06 RSX type S. It originally came from an 01 (ap1) S2000. I had plans of putting this into my Civic, but ended up choosing a SI cluster instead for money reasons. There is a problem though, right above the "SEL", there is a minor crack in the LCD screen. It doesn't affect the performance, but dI got this s2k cluster off a friend of mine. He had it in his 06 RSX type S. It originally came from an 01 (ap1) S2000. I had plans of putting this into my Civic, but ended up choosing a SI cluster instead for money reasons. There is a problem though, right above the "SEL", there is a minor crack in the LCD screen. It doesn't affect the performance, but doesn't look too pretty. Check the pics. Make an offer. I am not trying to make money off of this, just trying to get rid of it.
Here's a pic of the damage:
(don't mind the dust, just needs to be wiped off)
As I stated above, everything should work just fine, just the part of the RPM band that is affected may be blurred when/if you rev up that high. I do not have the plugs for the cluster, but has wiring coming out the back from when it was used on the RSX type S.
In order for this to work in your car, you will need:
- Your car's cluster wiring pinout, s2k cluster pinout (I can provide that if need be)
- Speedo-healer (unless being installed in a 05-06 RSX type S)
- EGT module from modifry.com (unless you don't care if the engine temp thingy doesn't work)
MAKE AN OFFER. Trades for parts for a 99 Civic welcomed! Nothing within reason will be denied! I just want this out of my dining room.oesn't look too pretty. Check the pics. Make an offer. I am not trying to make money off of this, just trying to get rid of it.
MAKE AN OFFER. Trades for parts for a 99 (6th Gen) Civic welcomed! Nothing within reason will be denied! I just want this out of my dining room.
Re: S2k cluster FS. Lowball me!
Thanks for the bump!
You could probably take the cluster apart (just a couple plastic clips) and spray the non-black part (where the crack is) with some VHT night shade from the inside to make it look clean. But I bet it would still be a little blurry (since the LCD is cracked) if you revved to around 8k. I was planning on painting it, but I decided not to and bought myself a SI cluster.
