RI: 94 frost white vx itr swap
Will take $3000 FIRM or trades for 96-98 EK hatch/ 92-95 ej1-ej2 coupe STOCK+CA$H!!!
NO RADIO INCLUDED / COMES WITH A P28 ECU RUNNING! dont like it dont buy it easy as that and no f*cking deliveries
Car/Color/Condition:
Frost white 1994 civic vx (200k+ on shell)
original metal thats been patched with bondo in the paaaassst starting to bubble again. Paint has some flaws and a spot i tried to sand and blend spray paint with lol...
READ READ READ
The motor was purcashed from a private owner with the trust that there was nothing wrong. I bought it, ran it, and it smoked at high rpms. Changed the valve seals with SUPERTECH seals and that barely helped. SO be aware your looking at a car that smokes at high rpms or when "Beating on it". Head gasket is NEW oem but still has a tiny leak at the right corner under the cam seal.
Engine:
unknown mileage-97 jdm itr motor(Motor smokes (Burns oil)at high rpms) changed the valve seals and that didnt help. I have reciepts for the head resurface+cleaning
runs on p28
New OEM headgasket/ARP head studs torqued twice/OEM alternator belt/Gates Racing BLue timing belt+ Gates water pump(have reciepts for most of those parts)
Avid mounts(hasport tranny side lol)
some type of jdm headers with the jasma carb stamp
2.25 str8 pipe to a greddy ti-c muffler.
Transmission:
gsr trans with exedy organic stage 1 clutch
Suspension:
energy bushings in the front lca's
skunk2 drop springs in front
Function7 lca's in the rear
Interior: Factory blue with 94 gsr front cloth seats. Alpine usb port radioRADIO NOT INCLUDED UNLESS YOU ADD$$$ Speakers are included with front+rear speakers
Exterior:
Sitting on Polished HX wheels(need to be finished)
spoon rep wing
amber corner lights
pwjdm sidemarkers with harness
Over all the car is pretty well taken cared of tho its not the cleanest thing around. Come take it for a drive before any business is done. Compression tested by a good mechanic friend of mine and the motor made #240 across the board. Still pulls really good just the smoking that i hate. LMK.
Will take $3000 FIRM or trades for 96-98 EK hatch STOCK+CA$H!!!
text with seriousness 401-648-5275
Heres a short 2nd gear roll i did. motor still runs the same
READ READ READ
Engine:
runs on p28
Transmission:
Suspension:
Exterior:
spoon rep wing
amber corner lights
Re: RI: 94 frost white vx itr swap
Were you not so Firm on the 2900$ from when you posted this before? http://hondamarketplace.com/showthre...6#post48907556
Notmyusername
11-15-2018 05:11 PM
