PA 1991 Honda Civic Wagon RT4WD Clean and OEM
Old 04-04-2010, 02:29 PM
underage's Avatar
Default PA 1991 Honda Civic Wagon RT4WD Clean and OEM
I'm selling my 1991 Civic RT4wd. This is a very clean and original wagon and almost rust free. I've owned it since 188xxx. I'll list what I know about it and then let the pictures do the talking...
UPDATE:I installed a jvc headunit and 6 disc changer as well as kenwood 2-ways in the front and rear. I also took pictures of the driveshafts. I want to clarify that all bushings, mounts, timing belt, and water pump are oem. The seals/gaskets in the motor are fel-pro.
Exterior:
Front end was repainted and the hood and right fender have clear coat. The left fender does not appear to have clear coat but is definitely repainted. The hood has a minor scrape on the right side.
The front bumper has a hole cut in it (not sure why) on the lower right area. Also has a mild scrape.
The roof rack is missing a tie down ****.
Minor dent in the left rear quarter panel. A single rust spot on the right rear quarter (I have seen no other rust on this car).
The clearcoat is flaking on the lip of the wheels.
Interior:
Left front seat is wore on the left bolster and the foam is somewhat deteriorated (its not as supportive).
There is no radio. I will put front speakers back in if I can locate the ones that came with the car.
There are 2 good sets of floormats, a jdm rear cargo cover, and rear speaker pods. It is a jdm cover because the usdm are grey and the jdm are black. Took me about a year to locate a soft cargo cover. Floormats are fairly hard to find as well.
Sometimes water comes in on the passenger side. Appears to come in the heater/blower box. I looked 2 or 3 times and couldn't find a thing wrong. It might do it every rain for a month and then not do it more than once for 3 months. Doesn't leak much, just a small spot on the floormat gets wet.
Mechanically:
Had a sohc zc put in about 10k miles ago. New clutch, throwout bearing, water pump, timing belt, cam seals, crank seals, valve guide seals, valve cover gasket, oil pan gasket. I use castrol edge synthetic and change every 4k (shortchanged the first time on the zc at 2k). I just (today, actually) changed the a/c idler pulley, the oxygen sensor, and the oil. The oil was still full when changed today. It uses/loses very little if any.
I replaced a power steering line about 7-8k miles ago.
A/C works well. Has a R134 conversion doesn't get frigid but gets very cool. It was recharged a year ago (when the conversion was done) and hasn't needed any maintenance since (aka no leaks).
The suspension bushings have around 30k on them in this car (some were used from my hatch and they would have around 50k). All were replaced.
Replaced front and rear motor mounts and the rear differential mounts.
The exhaust rusted out and was hurriedly replaced/made with a friend who "had done exhausts before". It didn't turn out that great. It works though.
I have two complete driveshafts for it. One has a u-joint that is almost completely immobile and one has a joint that is badly worn and vibrates a lot. The driveshaft shop said they could replace the joints in the driveshaft. Also supposedly someone is making a u-joint that is civic specific this year (see hondacivicwagon.com for more info).
The tires were replaced before the winter and have a max of 6k on them.
That's all I can remember right now. I will update if I remember more things. The car currently has 221xxx. I'm asking $3300 but very willing to consider offers. Located in Lancaster, PA.
underage is offline
Old 04-07-2010, 06:12 AM
ys1civicsi's Avatar
Default Re: PA 1991 Honda Civic Wagon RT4WD Clean and OEM
bump for a clean *** wagovan.
Trade for an h22 eg sedan with a little cash on your end?
ys1civicsi is offline
Old 04-08-2010, 06:30 PM
underage's Avatar
No thanks. I'm not interested in trading cars.
underage is offline
Old 04-09-2010, 11:44 AM
C-Rex1021's Avatar
^x2
C-Rex1021 is offline
Old 04-10-2010, 09:01 PM
underage's Avatar
Sold
underage is offline
underage
11-05-2014 04:52 AM
Vagitarian
Paint and Body
06-10-2014 03:48 PM
siblue_gzer
Northern California (Sales)
10
01-20-2013 06:46 PM
underage
Mid-Atlantic (Sales)
04-10-2010 09:02 PM
shortlid
11
11-27-2005 01:17 PM
Quick Reply: PA 1991 Honda Civic Wagon RT4WD Clean and OEM
