Honda B-series & D-series Parts <<Updated Daily>>
<FONT COLOR=""Black""><FONT SIZE=""4"">EVERYTHING MUST GO, OBO ON EVERYTHING
</FONT></FONT>
<U>94-01 Integra Parts</U>
Cusco Lightweight Flywheel-------------------180
Chrome Molybdenum Flywheel 8.00 Lbs
front lca------------------------60
rear lca-----------------------60
iac---------20
ls t/b------40
All 4 motor mounts---------100
engine harness-----------------------------80
Interior Harness--------------------------80
fuse boxes---------------------------60
air bags----------------------------100
b-series half shaft---------100
rack n pining--------------100
power steering pump-----------20
power steering pump hard lines--------20
integra radiator----------------60
radiator cooling fan-------------------40
Interior ac air blower-------------60
all ac lines----------------------80
ac evp can--------------------20
ac condenser unit--------------60
ac compressor-----------------40
pass side axle---------------------40
obd-1 dizzy----------------80
alternator---------------60
brake master cyc w/booster----------60
clutch slave cyc-----------40
2.5" exhaust piping w/ magnaflow muffler--------120
front turn lights---------------20
rear tails----------------40
rear body filler-----------40
hatch--------------------80
door panels----------60
rear interior panels---------80
black dash------------------80
rear plastics driver side----20
fuel pump--------------60
fuel tank---------------60
abs pump--------------60
Front wheel well plastics--------60
<U>Misc:</U>
If you need OBD-1 harness plugs let me know
single OBD-1 dizzy----------60
single OBD-2 dizzy----------60
LS obd-1 dizzy-----------60
obd-2 injecter clips-------------20
got a set of coilovers on stock ef struts----40
b & d-series clutch engament piston----------40
DA fogs----------40
DA red/white Tails---------60
1 EF/ 2 da rad support brakets----------20
obd-0 pr4 ls 5speed ecu-------30
DA cluster bazel with buttom and vents------40
DA rear body filler------------30
DA moldings with clips-----20
DA steering cover----10
DA hood latch braket & Latch unit---------30
DA steering wheel------------20
Da mud gurdes------------30
Da clutch cable--------------20
DA ingention with key-------------40
DA ingention with key & trank lock-------------60
DA front bumper mounting brakets-------20
Da T braket n tq---------------------20
Ek driver side mirror non-power-----20
B-series lower timing belt cover---10
d-series PP with disc-----------40
Altanator Brakets------20
B & D-series ac compressors------20 each
EF ac line-----------------60
B-series PR3 ac brakets-------10
Braket Master cyc DA Rs & Gs, bottom is DC2 Ls------40 each
Civic EX calipers------------------60
Civic EX New front rotors--------------40
D-series valve cover----------20
LS valve cover-------------------20
B-series ps top mount braket-------10
B-series PS pump-----------10
IAC--------------10 each
Honda Metal cooling Fan (Good for turbos)------20
LS head studs-------------------20
B-series Crank main cap studs-------------20
OEM radio block off plate
fits 94-01 integra's & 99-00 civic's
$20
EF ac lines
& DC ac line
also got ac compressers & condessor
have full ac system off my 94 integra with everything need
</FONT></FONT>
iac---------20
ls t/b------40
<U>Misc:</U>
DA fogs----------40
$20
EF ac lines
& DC ac line
front lca??? is that the front driver lower control arm? im in need of one. let me know - if so please email me @ nolicense526@yahoo.com
JDM_rolex
11-15-2011 05:26 PM
sleeperrex
11-12-2007 11:30 PM
