FS: 1998 Integra Turbo LS, Full Rebuilt, Garret Turbo 285-450 WHP $20K+ In Parts!
I'm selling my 98 Integra LS $5000 Firm
Almost everything has been replaced, NO EBAY PARTS USED!!
5 speed, clean title. I have put over $20,000 in parts into this car. I'm only selling it because I really need money for bills. The turbo itself is a Garret GTX2867r, I've hardly driven this car since it's been built, there's probably ~2500-3000 miles on the engine, turbo, and parts.
Everything has been done with OEM or better parts, no ebay crap. Turbo kit is from GO-AUTOWORKS. It was tuned on the dyno at Inline-Pro. The top and bottom end was built by Ray a master engine mechanic at Whitney-Automotive.
It's set for daily drive at 285 WHP right now. The boost can be turned up so it makes 450 WHP, it just needs a stage 3 or 4 clutch for that, Every part including the block(full forged internals, full top, bottom end) is supportive of 450 whp though, even has ID1000 injectors in there. Literally replace the clutch, get a re-tune and you're pulling 450.
Car was recently serviced at inline-pro in virginia, they replaced all the lines and checked compression. everything is perfect and no shaft play on the turbo.
I babied this car, i never took it to the track or the strip, did less than 15 pulls and most of them were only for 2nd and 3rd gear. I honestly changed the oil every 500 miles since the turbo was so nice I didn't want any oil contamination, used only rotella t6 5-40.
I never got to fix much of the interior, so the seats are a bit torn, and theres still some wires showing and stuff.
cons:
paint job is crap. looks great from 10+ feet away though, needs a bit of body work near the gas tank too.
passenger window only works sometimes,
odometer just stopped working at 160K or so, but the new engine/turbo/parts only has about 3,000 miles on it and i have paperwork.
The horn is a bit rusted and i haven't replaced it yet so it only works sometimes
interior isn't that great
I don't want to waste time haggling on a price, so the price is very fair and firm, at $5000. It's a steal for everything in there, you can part it out and make way more but I just need cash.
PARTS LIST:
Eagle rods
weisco forged 9.4:1 pistons
full supertech valve train
crower stage 2 cams
AEM adjustable cam gears
new waterpump
oil pump
turbo in-line oil feed filter
moroso oil pan
all new gaskets, etc.
ALL new hoses and silicone lines
motor mounts
front axles
excedy stage 2 clutch
aem lightweight flywheel
omni 3bar map sensor
ID 1000CC injectors
hondata s300
walboro 255 fuel pump
Custom 3" exhaust turbo back
Fake Catalytic Converter, will pass a visual inspection
HKS sqv 4 BOV(not a knockoff)
firewall oil T kit
Catch Can
AEM air fuel ratio gauge
boost gauge
oil pressure gauge
oil temp gauge
full suspension, and car lowered
all new rotors and pads all around(the really expensive hawk pads, this thing stops on a dime)
Go-Autoworks Downpipe 2 bungs
Go-autoworks FMIC Kit
Go-Autoworks Water/Oil cooling line kit
GTX2867r Turbo BOUGHT NEW! (3000 miles on it now)
Tial F38 Wastegate 1bar
Mac boost solenoid (boost by gear)
Brand new tires, only like 4,000 miles on them potenza RE-11
A bunch of security features to make it hard to steal which I won't describe here,
Door poppers(outside handles are disconnected, remote opens them)
Oil Cooler
Brand new lines, coolant, turbo feed, turbo oil dump
And a lot of stuff i'm forgetting!
Also please note, the puddles on the road are NOT from my car, there are NO OIL OR COOLANT LEAKS
cons:
PARTS LIST:
Eagle rods
crower stage 2 cams
new waterpump
oil pump
moroso oil pan
motor mounts
front axles
ID 1000CC injectors
hondata s300
firewall oil T kit
Catch Can
boost gauge
oil pressure gauge
oil temp gauge
Oil Cooler
Re: FS: 1998 Integra Turbo LS, Full Rebuilt, Garret Turbo 285-450 WHP $20K+ In Parts!
Selling for $5000, this is a great deal. I have bills and need cash asap. Going to part it out soon if no offers as I can make over $5000 from parts.
toxictom
05-31-2017 05:29 PM
