CT: FT 95 Civic DX
CT: FT 95 Civic DX
Hi H-T,
Im looking to trade my 95 Civic Coupe DX
I'm located in Stamford, CT.
I got the car 6 months ago and have loved DDing it. But i jumped the gun on buying the car because i needed a way to get to work. What i REALLY wanted was a white 92-95 civic Hatchback. I like the look a lot more and im just trying to test the waters and see if anyone is interested.
The Good:
Mileage: 148922 on body will go up as i DD it.
89000 on Engine JDM D15B w/ Si Transmission
K Sport Suspension
Stock EP3 civic Wheels
Unknown Header
K&N air intake
Apexi exhaust w/ 3in piping
JDM EJ6 Cluster
Center Console Arm Rest
AEM Fuel Filter
Wolo Horn
8k Hids
Clear Corner Lights and 50/50 Tail lights
Type R Lip
Stiff motor mounts
Short Shifter
Stage 2 Clutch
Rear Disc conversation
Drilled and Slotted front rotors
Radio and heater works. AC DOES NOT
Replaced Upper control arms >3k miles ago
Replaced Inner & outer tie rods >3k miles ago
Replaced rear main seal less than 5k Miles ago
Recently changed spark plugs
The Bad:
No AC
No Power Steering
Sounds like exhaust is leaking very slightly where it goes from 2-1. I was told it needs a gasket.
Car used to be turbo'd. I bought it when it was brought back to mostly stock and it runs very well. Idles a little low sometimes but never bogs and never cuts out. Always starts right up and still gets me great mpg
The Ugly:
Pervious owner tried to roll the fenders himself. Clearly it didn't go so well. I replaced the front fenders with 2 used ones. Both are completely un rusted. One has a small dent in it and the other is Frost white instead of Championship white, which the car is.
Rear quarters have a little of the classic honda rust.
Headliner is ripped around aftermarket sunroof. Sunroof doesn't work but also doesn't leak! Enjoy the skylight!
Thats pretty much all i can think of right now. Ill be adding pics to this thread later today, just wanted to get the facts down.
Let me know if you have a 92-95 Civic Hatchback, I will consider colors other than white but thats mainly what im looking for. Motor needs to have Vtec and must be standard.
The Good:
K Sport Suspension
Unknown Header
K&N air intake
JDM EJ6 Cluster
AEM Fuel Filter
Wolo Horn
8k Hids
Type R Lip
Stiff motor mounts
Short Shifter
Stage 2 Clutch
The Bad:
No AC
No Power Steering
The Ugly:
Lordofdark176
03-20-2010 07:14 AM
