Summer Special at Golden Eagle!
$100 off on sleeving for your engine!
- B Series (incl. B20b)
- H Series
- K Series
-We also sleeve D Series engines!
- Our "HD" (Heavy Duty) sleeves are rated to withstand up to 1200hp.
- Comes with a lifetime warranty against cracking.
- We can also blueprint and assemble your engine.
- Big bore capability.
Contact our sales team (or PM) for any questions you have for us or if you want a quote for your engine,
- Jon, (909) 592-4311 extension 13
- Bob, (909) 592-4311 extension 14
Re: Summer Special at Golden Eagle!
Build ''N'' Boost the Limit!
Crate Engines custom built Shipped World Wide
Boost up to 60 psi
Sleeves will not sink or crack
Ductile Iron sleeves
Boost up to 60 psi
August 2011 Newsletter
Golden Eagle
GSR Main
Stud Kits
in stock NOW!
(For more info
click here)
Golden Eagle
Accessory Kit
(For more info
click here)
Golden Eagle Sleeved Block
(For more info
click here)
We have the following cores available today
B16A2
B18B1
B18A1
B18C1
B18C5
B20Z2
D16Y7
H22A4
Golden Eagle
Vacuum Manifold
(For more info
click here)
Want more POWER?
If you need a sleeve job due to a cracked cylinder your engine may be a perfect candidate for our services. Your block with the cracked sleeve can be resleeved as long as the crack does not exceed the lower half of the cylinder. We can bring your engine back to life with additional strength and power by installing large bore cylinder sleeves that can add 200cc with ease.
The material we use is comparable to the barrel of an army tank. A general description would be 65-45-12 ductile iron that contains nodular graphite in a matrix of ferrite with small amounts of pearlite. In plain English it's strong but still not too hard that rings don't seat. Our sleeve design is not really a sleeve it's more like a whole new cylinder that is extended to the outer part of the water passage of the block. Unlike a stock block that has a raised spear of aluminum for each cylinder with a metal liner that has no support at the top. I 'm sure you are familiar with block guards; our sleeve design is comparable to four block guards stacked. We have race teams that boost up to 70 psi and yield 1300 hp without sleeve failure of any kind. We hold Military contracts here and besides making missile parts we play a big part in enabling you and your engine to beat the competition with strength and durability.
Golden Eagle Mfg. is located in San Dimas California. We are 30 minutes out of downtown L.A. Racing is very popular in our part of town and we are surrounded by race tracks. We have been known as the leading sleeve shop in the industry. You can boost up to 60 psi and hold 1200hp with our sleeves. This is the #1 reason why so many racers and teams come to us is. No wonder we sleeve a lot of the top record breaking race teams in the world.
Here is a list of a few teams we sponsor that have come to us looking for our sleeve service.
T1 Race development / Tony Palo
CMR / Chris Miller
Bisimoto Engineering
TODO Racing
World Racing / Christian Rado
The Brothers Racing
Lisa & Gary Kubo
Full Tilt Racing / Ed Bergenholtz racing
Speedfactory Tuning & Race Fabrication
We have our D Series Cam Gears available in with both black and silver inners. And of course they have the same high quality and easy read adjusting as our other models of Adjustru Cam Gears.
B18C (GSR) Main Stud Set
B18C (GSR) Main Stud sets are back in stock. We have a limited amount so hurry and call today. They won't last as the demand has been high recently for GSR Main Studs and with them unavailable we have been suppling ARP Main Stud Sets.
Contact us at 909-592-4311 or sales@goldeneaglemfg.com
Golden Eagle
GSR Main
Stud Kits
in stock NOW!
(For more info
click here)
Accessory Kit
(For more info
click here)
(For more info
click here)
B16A2
B18B1
B18A1
B18C1
B18C5
B20Z2
D16Y7
H22A4
Golden Eagle
Vacuum Manifold
(For more info
click here)
Want more POWER?
CMR / Chris Miller
TODO Racing
The Brothers Racing
Lisa & Gary Kubo
Product News
Back by Popular Demand!
D Series cam gears are back in stock.
Purple and Gold available in more products
We recently finished a run of B series Fuel Rails and B Series Cam Gears and we were able to add Purple and Gold to our product line. Purple and Gold is also available in Cam Seals, Vacuum Manifolds, Rear Front Tow Hooks and Dip sticks. Coming soon in Oil Caps. Call today to place your order for any of these items.B18C (GSR) Main Stud Set
www.GoldenEagleMfg.com or 909-592-4311 x 14
