Motorcycles Motorcycles and motorcycle parts for sale
PA GY6 Ruckus - Aberdeen Green $3000
Old 08-06-2014, 05:35 AM
bakertime's Avatar
Default GY6 Ruckus - Aberdeen Green $3000
*Price is Firm; NOT INTERESTED IN TRADES*
Up for sale is my 2005 Honda Ruckus with a GY6 Swap. I've owned this Ruckus for about 2 years now and purchased it from the original builder of the bike. An insane level of detail was taken when building this bike, which manifests in the details such as the custom headlight, turn signals, kickstand and more. It has approximately 1800 miles on the swap and still runs as strong as when I bought it. Has recent PA inspection (5/14), and oil/trans fluid/spark plug/ valve adjustment within the last 50 miles. Clean PA title in hand. Price is firm...either you're willing to pay $3000, or you are not. If not, than don't contact me.
Here's the main mods done to the bike:
2005 Honda Ruckus w/ approx 1800 miles since build
Honda Aberdeen Green paint
Line-X coated main frame and stainless gas tank cover
Custom single headlight
Dual footpeg positions w/ PWJDM pegs
11 Pole stator upgrade
Mini fatty w/ Composimo GY6 mount
NCY Front end with big disc brake kit
Vapor digital speedometer/tach
Custom removable exhaust silencer
Custom adjustable kickstand
Custom cut CVT cover
Harrison Specialties LED turn signals and tail lights
Kitaco frame extension footrest
Composimo starter cover
Advance Pro rear shock
KCP billet locking gas cap
Standard Functions wiring harness
Custom stainless exhaust
Black powder coated wheels
Mini fatty hub
NCY Variator
Large underseat storage compartment
DK Alpha BMX Stem
Makoa billet frame caps
Bar-end mirrors
Billet Fuel Pump bracket/ Mikuni fuel pump
Adjustable performance CDI
Gates Kevlar belt (<100 miles)
Uni filter & custom intake tube/bracket
Performance Clutch Torque Spring
Anodized Red Aluminum Magnetic drain plug
GY6 Rear Fender
Michelin Bopper tires
Couple things to note:
-When I bought this bike, it had a 30mm carb that got the bike up to over 65 mph with the exhaust silencer removed. The rubber diaphragm tore on the old carb and I was not able to find parts for it, so it currently has the 24mm stock GY6 carb, jetted for this intake/exhaust setup. it currently does between 55-60mph depending on if the silencer is installed. (I weigh 175#)
-I have a modified stock front fender that can be slipped on and off for inspection purposes
bakertime is offline
Old 08-06-2014, 05:48 AM
STR8 to Ignore List
STR8 H8N's Avatar
Default Re: GY6 Ruckus - Aberdeen Green $3000
STR8 H8N is offline
Old 08-06-2014, 08:03 AM
bakertime's Avatar
I'm not sure why you're smacking your forehead over that...the bracket was cut, made skinnier and then welded back together before it was painted to accommodate one light instead of the original two. Some like it, some don't, but it is a custom part.
Old 08-16-2014, 03:26 PM
bakertime's Avatar
Bump!
Joepiper151
Motorcycles
05-21-2009 02:02 PM
arjusmc
Motorcycles
11-13-2008 04:22 PM
HtC_SiR
Motorcycles
07-27-2008 05:48 AM
EVOLMTR
Motorcycles
04-10-2006 08:18 PM
Quick Reply: PA GY6 Ruckus - Aberdeen Green $3000
