Mid-Atlantic (Sales) VA, DC, and MD
MD: FS: Frost White '92 Civic CX STOCK, CLEAN!!!
Old 09-13-2011, 03:59 PM
g2_teg_'s Avatar
Default MD: FS: Frost White '92 Civic CX STOCK, CLEAN!!!
Means of contact: kyle10182@gmail.com
Price: $3550
The car is a 1992 Honda Civic CX hatchback. It is a 5 speed manual. Only mods are GSR lower control arms, and LS front/rear sway bars. The car has 132,xxx miles and that number will go up. This car gets awesome gas mileage. The corner panel has some little damage that is not noticeable from 10' away. Everything about this car is solid.
Pictures:
g2_teg_ is offline
Old 09-14-2011, 10:47 AM
g2_teg_'s Avatar
Default Re: MD: FS: Frost White '92 Civic CX STOCK, CLEAN!!!
bump
g2_teg_ is offline
Old 09-15-2011, 02:27 AM
slowcivic e g's Avatar
Bump for clean stock cx.
slowcivic e g is offline
Old 09-15-2011, 11:01 AM
g2_teg_'s Avatar
thanks
g2_teg_ is offline
Old 09-15-2011, 11:14 AM
navin's Avatar
You should pull off the rubber seals in the fender wells and check for rust: first thing you should pull on Hondas
navin is offline
Old 09-15-2011, 03:30 PM
thirteen20CRXSi's Avatar
^ you know if you do have rust then removing it will make it grow faster.
thirteen20CRXSi is offline
Old 09-15-2011, 07:48 PM
navin's Avatar
The rubber seals are just gonna keep trapping moisture in there. If there is rust underneath, the seals should be pulled and it should be fixed correctly.
navin is offline
Old 09-17-2011, 12:32 PM
g2_teg_'s Avatar
09/17/2011
g2_teg_ is offline
Old 09-18-2011, 07:41 AM
g2_teg_'s Avatar
bump
g2_teg_ is offline
Old 09-20-2011, 11:07 AM
g2_teg_'s Avatar
09/20/2011
g2_teg_ is offline
Old 09-20-2011, 12:48 PM
EF Boy1231's Avatar
super duper clean. bump
EF Boy1231 is offline
Old 09-22-2011, 04:20 PM
g2_teg_'s Avatar
bump
g2_teg_ is offline
Old 10-01-2011, 12:04 PM
g2_teg_'s Avatar
bump
g2_teg_ is offline
g2_teg_
09-26-2011 08:30 PM
-DC2-
02-24-2003 07:31 AM
SoCaLNaTIvE
01-28-2003 05:48 PM
Quick Reply: MD: FS: Frost White '92 Civic CX STOCK, CLEAN!!!
