oGarage/ all motor build clean out.
2001 part out. The shell is sold, everything else is still for sale. I'm located in VA beach, I can meet up around the area, or I can ship pretty much anything any where in the USA as long as you are pay pal verified, vouch thread in the sig.
TXT for fastest response 7049893666
Hasport mounts for b series eg 3 post - 200
Skunk 2 intake manifold with no rail or throttle body- 160
Blox throttle body with all sensors- 90
Golden eagle fuel rail. - 80
Ls vtec kit every thing but the headgask for obvious reasons- 150
Brian crower stage 2 cams - 350
buddy club adj cam gears- 80
Type R head, port polished, new over sized valves, new dual springs and retainers, port flowed the works. comes with vtec solenoid. 1300
Type r valve cover and oil cap. 120
Megan header -100
Aem wideband erverything from sensor to guage- 120
Aem pcm series 2- 600
Linkage - 50
half shaft- 40
Stage 2 clutch and light weight flywheel 200 will get brand later once I pull trans
Apexi world sport 2 cat back including the oem cat 350
golden eagle block guard- 50
blox rear sway bar for eg/dc with good endlink- 120
oem Honda battery- marked 7/16 with 100 month warrenty- 60
skunk 2 weighted shift ****. -50
ebay rays knock off wheels - 100 with tires. all wheels hold air one has a small gouge in it from a curb.
obd2 gsr engine harness -100
obd2 ls harness 70
vtec subharness for non vtec harnesses -50
i'm going to add more parts and I clean my garage through the day. Once it's organized I'll add pics and prices.
Pm me for pics of anything specific.
Megan header -100
Linkage - 50
half shaft- 40
obd2 ls harness 70
luvmihatch
04-03-2017 10:25 AM
stuff that needs to go asap b series d series nitrous,everything must go!***************************
stockcolt
10-09-2006 04:05 AM
