FS: MD: JDM 98-01 ITR 5 lug 36mm suspension/brakes
Selling my 5 lug brake/suspension setup. In perfect working condition and still on my vehicle. Front setup will include front knuckles with 36mm hubs, extended wheel studs and fairly new wheel bearings and ball joints. I can also include B-series 36mm axles or outer joints if needed. Rear setup will include fairly new ITR hub and bearing assemblies, spindles and Mazda axle nuts.
Brakes are Prelude VTEC calipers up front (same as ITR), RSX in rear (same as ITR), drilled and slotted rotors all around which only have a few thousand miles on them and are still in perfect condition, not warped. Will include e-brake cables, brackets, etc. as well as ITR 1" brake master cylinder with booster.
Looking to get $800 OBO for everything. PM if you are interested in different pieces, may part out.
I have a set of good set of 16" 05-06 RSX base model wheels with BFG all season 205/60/16 tires if anyone is interested in them. Also have a BIN Honda accessory wheels in 15".
