CLEAN 1989 CRX HF Shell (Part Out) - Honda-Tech
Mark this thread as UnSold
Closed Thread
Old 08-25-2016, 07:39 PM   #1
Default CLEAN 1989 CRX HF Shell (Part Out)
John
Manassas, Virginia
703-789-1655
Cash/credit card/paypal
***TRADES-Guns/Rims/Racing Seats/Evo Parts/NEW Turbochargers/Running Car****
*SHELL SOLD*
**IF IT IS NOT LISTED. IT IS SOLD ALREADY**
PARTOUT PRICES:
-AEM 3.5 Bar Map Sensor $75
-GM 3 Bar Map Sensor $20
-Aeromotive Fuel Pressure Regulator With Guage $100
-Aftermarket Fuel Pressure Regulator $30
- Modded FIC 750cc Injectors $150
-Resistor Box $35
-Neo Chrome Razo Shift **** $10
-Unknown EF Mounts For Use With A Cable Trans $150
-Hasport cable to hydro conversion with cable $100
-Fastline Performance "Road Race" Tall Shifter $150
-Buddy Club Shift **** $20
-OBD1 B-Series Non Vtec Distributor TD55U $50
-OBD2 B-Series Vtec Distributor 50
-B-Series Hydro Starter $50
-OEM 92-95 Civic Half Size Radiator /Hoses $40
-Samco Radiator Hoses $60
-2 cheap Intakes $10
-CRX Custom 2.5 inch exhaust with new dual Si tips Built by SLS (quiet and OEM look) $250
-EF/CRX Custom Traction Bar $200
-EF/CRX Custom Harness bar With Hardware CRX $150
-NEW EF/CRX ST Rear Sway Bar With Hardware $125
-Front Black Tow Hook $10
-Jdm del sol cluster $75
-NRG Quick Release Lock (black) $50
-Custom charge harness for battery relocation $20
-Password JDM Brass shift **** $40
-JDM Rear Back Seats With Bolts Brackets (top portion needs re-upholstered) $200
-OBD2B To OBD1 Jumper Harness
I had this on my 99 Si to be able to run an OBD1 Hondata S300 Ecu $50
Converts any:
• 2000-2001 Acura Integra
• 1999-2000 Honda Civic
• 1998-2002 Honda Accord
• 1999-2002 Honda CR-V
To run any OBD1 1992-1995 ECU.
-I have a set of Corbeau Driver and Passenger Seat Brackets (No Sliders) for sale. Bought the wrong ones so now time to sell them $60 each or $100 for both.
-I also have a passenger side seat rail that came off my 1989 CRX HF painted the OEM Blue, They are side mount design. $60
-NEW Volk formula lug nuts 12x1.25 (20) $70 subaru/nissan
-Precision Injector Clips $10
-Custom aluminum radiator stay $5
-Odyssey PC680 Battery $25
-Oil pressure sensor/sending unit $25
-Lexus is300 cluster $50
-94 integra a/t cluster $20
-02 WRX cluster $4
-K20 coil pack cover $5
-H4h jdm headlight bulbs-yellow $20
-NEW Rsx rubber door weatherstrip $3
-Hondata k20 thermal gasket $20
-RSX-S OEM DIFFERENTIAL $20
-NEW Blue wire loom $5
-2 wheel spacers $20
-Signal auto catch can $35
OEM GSR Flywheel $20
1999-2000 Honda Civic BMW Z3 Metal Fenders, black in color. Not the cheap fiberglass versions.
These retail for $250+
Im asking $50/obo/trades
Everything is sold as is. It is up to you to test it/look it over/do your research to make sure it fits your vehicle/motor.
slow sol is offline
Old 08-28-2016, 05:32 AM   #2
Default Re: CLEAN 1989 CRX HF Shell (Part Out)
Bump
slow sol is offline
Old 08-30-2016, 10:37 AM   #3
whitecvcb16's Avatar
How much for the radiator support
whitecvcb16 is offline
Old 08-30-2016, 10:45 PM   #4
Parties with 2LEM1
Brice.Hayden's Avatar
Try reading...
Brice.Hayden is offline
Old 09-01-2016, 09:27 AM   #5
Updated info
slow sol is offline
Old 09-04-2016, 02:35 PM   #6
Updated
slow sol is offline
Old 09-06-2016, 06:54 PM   #7
Skunk2 header SOLD
slow sol is offline
Old 09-10-2016, 09:07 AM   #8
do you have the Climate control ??
billscrx is offline
Old 09-13-2016, 03:32 PM   #9
I had 2, now i cant find them. Might have been snagged by somebody 👎🏻
slow sol is offline
Old 09-22-2016, 05:40 AM   #10
Prices lowered
slow sol is offline
Old 09-30-2016, 05:43 AM   #11
Prices lowered
slow sol is offline
Closed Thread
CLEAN 1989 CRX HF Shell (Part Out) slow sol For Sale 9 10-02-2016 08:36 AM
89 CRX HF Clean Built GSR-Turbo Ready-Possible Partout slow sol Mid-Atlantic (Sales) 2 08-16-2016 04:54 AM
89 CRX HF Built GSR-Turbo Ready Partout slow sol Classifieds: Forced Induction 13 08-16-2016 04:52 AM
89 CRX HF Built GSR-Turbo Ready Part Out slow sol For Sale 9 08-16-2016 04:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
