Lighting HID/Xenon kits, Retrofits and Associated Topics
TSX retrofit into 92' prelude JDM black housings!! (56k die)
Old 01-16-2010, 11:36 AM
n0rmaL's Avatar
Default TSX retrofit into 92' prelude JDM black housings!! (56k die)
since im in the process of doing this and found that theres no real good write ups or info for the 4th gen prelude, i will be making this thread for any questions you may have.
i'll be updating this thread as i finish my retrofit and hopefully it will help others out with their own retrofits.
first off get some projectors!!
i went with the TSX projectors cus there are easy to get, have a nice cut off and arent too big unlike the s2k projectors for example.
they are from an 06 model so they had the fresnel lenses but i ordered some clear lenses from the retrofit store.
i have the JDM 1 piece so sorry for you USDM guys and gals :lol: preheat oven to 350 degrees. remove the 5 metal clips from the headlights and of course the bulbs and rubber caps. theres also 2 bracket things, remove those also, it is 2 screws each. place the headlight on a cookie tray with a towel under it. turn the oven off and place in over for 8 minutes. remove after 8 minutes and carefully start to pry at the edges with a flat head screwdriver. take your time and work carefully! it should comes off after you have went around the whole headlight with your screw driver.
making poorman custom shrouds...
i got this idea from hidplanet forums, you get a 3''-4'' abs plastic reducer from the heating air duct isle at home depot and a travelers coffee mug from walmart, total cost under 10 bucks!! take the chrome ring off the coffee mug lid with a flathead and trim the reducer to fit nice and snug over the projector housing
the reflector bowl and the top half of the projector, i was test fitting and seeing how much needs to be trimmed... its alot
[img]https://i474.photobucket.com/albums/rr103/hotprelude97/HPIM3082.jpg
i cut the holes today and did some more test fitting, still trying to figure out how to mount them and aim them right.
after some research on hidplanetforums i found some other guy used this mounting method and it seems to work pretty good. i got the hardware from home depot, 1" L brackets, #8 32x5/8'' nuts and bolts, and #8 washers and lock washers (i used the washers for color mod). so far i only mounted one side with a nut and bolt so i can go test out the cutoff level and make adjustments before securing the other L bracket. im still gonna put some jb weld on the back of the prjector and reflector bowl for extra strength
put the headlights on and did some test aiming, these are with the fresnel lenses BTW
heres some pictures of the projectors all mounted up in the housing, upgraded to ninja star lock washers and nylon lock nuts. i dont want to risk these things coming loose on me
got my cut off as level as i can, these are with the clear lenses BTW
i added a 3rd upper mounting bolt, to keep it more secure. i got 1 1/2" bolt with a nylon lock nut and some lock washers on both sides.
ok so i gave up on my custom shrouds because they didnt really cover everything the way i wanted them too plus splatter punk basically gave me some e46 shrouds for free. thanks again bro!! i had to trim then alot to fit, mostly the top part and some of the bottom
this is the stuff i used to attach the shroud to the projectors, works really well i think and gets rock hard in 10 mins and can withstand high temps up 500 degrees.
then i attached the shroud..
then i added some foil tape, to the exposed parts in the back
after putting the projector back in the housing, you have to trim some of the black plastic piece thats held in the headlight lense. remove the 2 screws and remove the black piece, then trim as needed to fit the projector and shroud.
i also had to trim the back of the housing to fit the bulb clip, and make sure it works and doesnt rub on anything
now clean everything off really good and put the headlight lense back on the housing.
sealing the headlight back up, i used the same method i did to open the headlight, but only 300 degress this time at 8 mintues. the little metal clips that come with the headlight really help holding it together when you go to reseal it, just a tip.
install onto car and enjoy, you just saved yourself about 200-300 bucks
Old 01-17-2010, 05:43 AM
Slain's Avatar
Default Re: TSX retrofit into 92' prelude JDM black housings!! (56k die)
awesome job. i've never seen those foglights before on a prelude they look like the 93-95 sir integra fogs
Old 01-17-2010, 05:52 AM
Hawkze_2.3's Avatar
Sweet write-up You didn't mention the ballasts and ignitors...or am I missing something? Also, did you use a relay harness to prevent the stock headlight wiring from being overloaded on startup?
Old 01-19-2010, 12:27 PM
New User
hondaprofile's Avatar
Great DIY and post, thanks for this.
Old 01-19-2010, 12:38 PM
n0rmaL's Avatar
i had an H4 hid PnP kit so yea, it was plug and play once i got the D2S adaptors from the retrofit source
Old 01-19-2010, 01:08 PM
Oo0MaRkY0oO's Avatar
do you have any pics of the cutoff once mounted back int the housings with headlight lens on? I got a tsx retro on my integra and my cutoff is not as clean as yours was. There is a lot of lens flare toward the end, almost looks like two steps. I think it has to do with the lines on the headlight lens. I will try to get a pic on here to better describe it.
Old 01-23-2010, 06:32 AM
n0rmaL's Avatar
no i havent gotten any yet, its been raining like crazy over here the past week and plus my digi cam just took a **** on me. but after i put the headlight lens back on i did notice lens flare above the cutoff line, i guess the only thing you can do is get the ebay replicas with the clear headlight lens, well they make them for preludes idk about tegs
Old 01-27-2010, 07:27 PM
goomzthegeneral's Avatar
they look sick.
Old 02-03-2010, 06:35 PM
1StepConcepts's Avatar
Nicely done!! those look clean *** hell..
Old 02-04-2010, 09:59 AM
New User
FreddyG's Avatar
Looks superb. I plan on retroing my prelude headlights the same way with the stuff from the retro fit I did on my accord.
Old 06-17-2010, 03:18 AM
cannabis9478's Avatar
Sorry to dig this up. i am looking at doing this as well.
The direction of the porjector should be the same as the origila light right?
How do you align the projector angle to be the same as the original light?
is there any markings on the projector?
Old 06-17-2010, 08:03 AM
chawski's Avatar
aim your stock headlights against your garage so they are as good as you can get them. mark where the step is, and where the low side (left) cutoff is. Use this as a jig so when you mount the projectors, you can match the cutoffs. keep in mind it will take some trial and error, but its gonna get you pretty close
Old 01-10-2011, 08:11 AM
n0rmaL's Avatar
so I finally did the devil eyes mod to my tsx projectors, I've been wanting to do this mod for along time now I've just been to lazy to open my retrofits back up lol I still have to bake them in the oven to cure the paint but so far so good......
Here's a last look at the old set up
Then I cracked them open
Got some supplies
Painted the shields
Here's what it looks like so far
More to come.......
Old 01-10-2011, 09:03 AM
xunsungheroesx's Avatar
confused. explain what this mod is? just red paint on the lens assembly?
Old 01-10-2011, 02:27 PM
Blazin Si's Avatar
I thought the "demon eyes" mod was painting the shield red so that the projector lens looks red during the day?
Old 01-11-2011, 05:56 AM
n0rmaL's Avatar
read the post below, this mod doesnt affect the light output whatsoever
yes it is and thats what i did lol
Old 01-11-2011, 06:03 AM
n0rmaL's Avatar
this is what it should look like when im done..
Old 01-11-2011, 06:15 AM
PatrickGSR94's Avatar
holy damn that looks freaky lol... not really for me, but great work on the Prelude headlights, though. Want to toss my Hella bi-xenons for TSX's soooo bad.
Old 01-11-2011, 03:07 PM
Blazin Si's Avatar
I see, I didn't understand your photos. It looked like 5 pictures of a taped up projector housing with the lens still attached. It turned out really good. I've seen some guys put red LED's inside the housing also, but that's a little too much. lol
Old 01-14-2011, 05:29 AM
n0rmaL's Avatar
updated 1/14/11
i baked the shields to cure the paint (the heat helps the paint bond to the metal)
then i re-assembled the projectors
Old 01-15-2011, 08:46 AM
n0rmaL's Avatar
updated 1/15/11
sealed the headlights...
Old 01-15-2011, 08:00 PM
n0rmaL's Avatar
updated 1/15/11 9pm
put them on the car
Old 01-15-2011, 08:24 PM
Haha dang that looks nuts in the daytime! Really great work dude.
Old 01-16-2011, 07:13 AM
n0rmaL's Avatar
^^thanks man
heres a few more pictures in the daytime
nuttyvtec
05-29-2016 03:29 PM
n0rmaL
12-21-2013 07:09 AM
h10ndr
10-02-2010 07:36 PM
LilBoi
11-08-2006 03:22 PM
FalconMan
12-11-2002 08:37 PM
Quick Reply: TSX retrofit into 92' prelude JDM black housings!! (56k die)
