Lighting HID/Xenon kits, Retrofits and Associated Topics
tail lights and corner lights always on
Old 11-09-2015, 09:06 PM
bigtimegambler's Avatar
Default tail lights and corner lights always on
My 1990 civic is fitted with an HID kit and no matter what setting of the lights (off, Amber, low beam) the corner lights and tail lights remain on. Is it because the HIDs were hacked into the the lighting system?
Old 11-10-2015, 02:16 PM
LowTEC SaiMike's Avatar
Default Re: tail lights and corner lights always on
are the lights Dim looking ? if so that might be a ground issue .
Old 11-10-2015, 02:34 PM
Thank you for your suggestion, I will have to take a look at my grounds. My HIDs are bright, and I think the tail lights and corners are the correct brightness. Is there any other causes which would make the tail lights and corner lights stay on in the "off" position on the light stalk?
Old 11-13-2015, 10:51 AM
Either the switch , ground , or harness is looped to ground
Old 11-13-2015, 04:19 PM
Thank you !
Old 11-13-2015, 10:22 PM
Keep us posted what you found :thumbs up:
Old 12-01-2015, 11:29 AM
I didn't find any issues with the grounds. Not really looking to dig into the harness to find an issue. Its not a safety issue so ill just leave it how it is.
Greyout
12-24-2003 12:19 PM
Quick Reply: tail lights and corner lights always on
