need help with some side markers here
i bought soma side markers for my teg how do i wire them to where they light up at night and blink as well thanks
Re: need help with some side markers here (97tegblk)
get a hold of your turn signal wire harness. there should be three wires. Connect the black wire to the negative wire on the side markers. Connect the red with black strip wire to the positive wire on the side marker. leave the green wire alone
The correct answer to the OP's question has yet to be posted.
Search for "sidemarker" in post bodies of archive posts created by my user name and you'll find plenty of info.
OP: since you have a 97 Integra, the side 194 bulbs on your bumper lights should also come on and flash, the same way you want your side markers to function. An easy method would be to just tap those 2 wires and not mess with the 1157 bulb in the bumper light.
Re: need help with some side markers here (thegreat0ne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegreat0ne »</TD></TR><TR><TD CLASS="quote">get a hold of your turn signal wire harness. there should be three wires. Connect the black wire to the negative wire on the side markers. Connect the red with black strip wire to the positive wire on the side marker. leave the green wire alone</TD></TR></TABLE>
works, guranteed
works, guranteed
works, guranteed </TD></TR></TABLE>
Yes, that will work to give you the correct sidemarker function of turn signal only. But that's not what the OP is looking for, as clearly stated in his post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegreat0ne »</TD></TR><TR><TD CLASS="quote">he wants them to stay lit when the lights are on and blink when he signals, doesnt he?</TD></TR></TABLE>
yep, and the process you described would make them blink only.
90_EX_Civic
03-21-2009 07:59 PM
ATL_gingerkid
02-17-2007 10:46 AM
