Bad ground headlight/blinker
Fixing bad ground
Fixing 1996 Honda Accord LX F22B with parts car.
Started on lighting system replaced fuses relays bulbs and switch.
When I flip lights on nothing except running lights. On dash passenger blinker light comes on and stays on if I apply negative power from battery to frayed and stripped blinker Ground the headlight comes on for that side. I don't know about the driver side apply negative power from battery headlight on passenger side still illuminates but not driver. What should I do with the ground. And how should I track down the drive headlight issue?
help would be appreciated
Thank you
Capt. Kirk
Thank you
Capt. Kirk
bigballer8526
05-09-2017 05:59 PM
pliskin679
01-27-2013 03:40 PM
