How to - JDM ITR HID Headlight and Fog Light Wiring
#101
Re: How to - JDM ITR HID Headlight and Fog Light Wiring
What happens if you have a 2001 fuse box?they don't look the same for the foglight wiring.any help would be appreciated .I can't figure where to plug into the newer fuse boxes
#104
After 6 years ive decided to wire my fogs up.
Is the tutorial for use with the jdm fog light switch, or can you use the usdm cruise control switch?
Ive wired according to tutorial but im not getting 12v output on the green wire with cruise control switch depressed.
#107
Where,I can get the male brown conector .?
i got the non hid black headligths
The conector i need its to plug the wires.
My front end dont came with it ?
I only have the one with the headlights. And its the female.
What I can use to make it work. ?
#113
I know this thread has been dead for a while but I have everything wired up like describe but I have no power coming out of the green wire...I tried a different cruise control switch and nothing, any ideas.
#114
Blk/Yel & Red/Blk wires= tie together and run to power.
Blk & Red wires= tie together and run to ground.
Helms Schematic:
Helms CC schematic
You can see why wiring the two black wires to ground gives no power & why the two red wires together is wrong.
#115
For anybody else who have no power on green wire I solved it. The wiring is wrong. This is how it should be wired:
Helms Schematic:
Helms CC schematic
Helms Schematic:
Helms CC schematic
#116
This is a helpful topic so I screenshotted the OP and hosted it on imgur in case we lose the original images in the future.
http://imgur.com/a/AEeYF
#117
I know this thread is old but I'm wondering, is their a passenger/driver flasher relay or running light relay, I have the itr front but for some reason, my passenger city light and fog don't work but thrived side does, headlights both work and no highlights,
#119
Very nice and easy to follow instructions i did this in 20 mins cant say i am tech savvy but i did exactly as the instructions say and had exactly the relay and wires to wire it up. Used the cruise control button i will clean this up and put it all in tomorrow...hope no one driving my car decides to use the cruise control...LOL...
b16crx0062004
10-13-2004 07:06 PM
