HID retrofit club
#2826
Re: HID retrofit club
The power wire goes under the positive battery wire and then over it onto the terminal. I had slack on te wire so I tried to minimize going that route instead of straight to the battery. The rest harness is kinda bunched by the coolant bottle and the battery. Maybe this is causing the. Problem? I'll post pics later I'm at work now. Do u have a 8th gen si? How did u run the harness?
#2830
So I went outside to take some pics with my phone and if the car is not on or running the noise is not there. But if the key is in te I or II position or running the noise is there. I'll have pics for u later tonight. Thanx for the help btw
#2833
Hey guys just got my setup today. This will be my first retrofit Coming of a 09 Dodge Charger hid version. I can use as much tips or guidance as possible. If anyone wants to pm some major advice (THAT WOULD BE AWESOME!) Projector has this mini motor mounted with a red & black wire and a metal piece blocking half of the projector inside. What is that?
#2838
I need help too? I have a pair of range rover projectors. they look just like the ones one the very first page and im trying to put them on my denji's
#2839
#2842
#2843
try running all that wiring down that loon where the radiator cap is.. that wiring goes to the front of the car and u should still be able to have the harness reach the ballasts...
#2844
Edit: and exactly where did u mount the ballast to? the actual fender?
#2847
The denji projector is 3" but that doesn't mean u could put a 3" hid projector in... I've talked it over with people and there just isn't room to put them in... that's y I settled on 2.5 in projectors... I'm selling my denjis with rx330 projectors
