HID retrofit club
#2501
Re: HID retrofit club
sounds like the ballast is going out to me. If it were the bulb, it would not have come back on at all.
<- 6-yr old Philips ballasts and 5-yr old Philips bulbs still going strong
#2502
Okay I began my retrofit this weekend.. While i was looking at the cut off's etc I notice how they look when you use the clear lenses.. So I had to figure out how to get it done with the clear lenses.. while I was testing how the cut off look I notice you had to space the lense out alittle to make the cut off sharper... I dunno some people call it a color mod i guess.. It makes a sort of purple color next to the cut off.. I dunno if it was worth my time but I just had the lenses so I thought why not.. and I couldn't sell them cause I got flamed on my local forum anyway.. they are g35 projectors with aftermarket halogen projector clear lenses .. the ones with the purple tint... So I HAVE G35 CLEAR LENSES FOR SALE if anyone wants them.. . Okay so on the to the pics...
Aftermarket projectors
Stock cut off of the g35 lenses and projectors..
Okay that was all I got done today.. it took forever to figure out how to properly mount the lenses.. I was a pain in the *** I am dissapointed that i didn't get to make the brackets to mount the new projectors in the aftermarket light houseing's but when I was looking on the internet i found some cool things i could do like mask my halo angel eyes to make them look like the ten star led shrouds that i have seen.. well piece out..
#2503
1. The space in this area is about 1/2 inch
2. This rim is resting on the the stock seat of the old location where to stock lenses would have been.. The only reason I did this is because they fit almost perfectly on there which means i didn't have to center anything just used loctite liquid metal while still getting 1/2 inch spacing that i needed...
The reason i needed this much spacing is becuase I was using the incorrect lense size and this size in the stock position would not even focus at all.. When I backed it off my cut off was extremely clear with lots of color and only color above my cut off.. absolutly no light above my cut off.. I will have to post pics of the cut off when im done but right now im trying to get the brackets done... but for now here is the cut off at about six feet with the mod that i have done...
There is more light but it was hard to hold the bulb as the right spot will holding the projector and camera.. lol
#2507
#2510
#2511
I'm trying to get some good 2.5 inch clear lenses but I am still going to mod the little adapters I made to see how the cutoff/output looks don't worry the g35 projectors will be fine all they have is some glue on them nothing I can't get off.. And the lenses I have now are really clear.. Its hard to find clear 2.5 inch clear lenses the FX35 lenses are kind of blurry and the rest are TL and RSX lenses which are not easy to get the just the lenses...
#2512
Get TSX, Valeo, 300zx, Retrofit source TSX or FX copies. DONT mess with the shield, everyone says you have cut or bend these to get color and its completely false. A good clear lens and correct spacing are all thats needed.
#2513
i found out its the bulb and not the ballast. what i did was switch the pass bulb over to my driver side ballast and it still flickered on for like 5 seconds and went dead. when i put the driver side bulb on the pass side ballast it worked fine. so its definitely the bulb. so i just swapped in one of the four extra sets of HID kits that i had lying around. this set has smaller ballasts.
#2514
HI I would like to retro fit my 01 civic sedan,I have the HID's but there kinda weak plug and play. Anybody know what donor car I can use? And for all you guys that get your car retro fitted with a donor car's headlight's,do you go to the junk yard? Or buy em at your local dealer,e-bay? Any help would be appreciated,thanx.
#2516
#2517
Seems like alot more heads are getting into the retro scene. Thought I'd post some pics up to assist some of you first timers who are doing Gen3 Integra retros. The projectors shown below are TSX projectors, but I've sucessfully retro'd Land Rover bi-xenon projectors as well and they actually have a very nice cutoff. Sorry no pics of those.
I really like how the TSX projectors fit like a glove here. With the bigger Land Rover projectors I had to dremmel a small section off the shroud.
Good luck, and happy retrofitting.
#2518
#2519
Should have my retro on my car by next weekend.
s2000 Projectors w/ New Retrofit Source TSX-R Clear Lenses (opted to replace the OE ap1 clear lenses)
Retrofit Source e46-R Shrouds
Philips 85122+ Bulbs
Digital 55W Ballasts w/ AMP Adapters
Output shot of same setup...
#2520
#2521
Beautiful cutoff. That is amazing.
#2525
oh btw if anyone has an d2s bulb retaining clip for an e55 hella bi-xenon projector please pm me. i really need it. willing to pay generously. i tried a dealership but they supposedly only sell the whole headlight assembly. i currently have a paper clip holding my bulb in.
heres a pic of the clip that i need. its on the projector on the right.
