Lighting HID/Xenon kits, Retrofits and Associated Topics
help with high/low beams
Old 03-12-2010, 12:32 AM
ef yu's Avatar
Default help with high/low beams
okay so heres the situation
my car (1989 crx si) has the original 9006 head light plug. i switched to the JDM EF8 front end and those headlamps are using H4h.
i made a conversion harness, a 9006-h4h plug (without high beams) for now. I want to use the high beams but seeing how my original wiring harness uses 9006&9005 for headlights low/high beam wont work as it can blow out the bulb if i wire them, wire for wire.
As 9006/9005, low beam are on and when i turn on the high beam, the 9006 AND 9005 bulbs are both on.
As for H4h, low beam is on and when i turn on the high beam, the low beam shuts off and high are on.
is there a write up to wire up a relay to turn off my low and leave the high beam on as the high beam are hot?? i googled up those SPDT relays but i just cant seem to figure out how it would be wired.
I drive a lot at night and in some areas on the way home, id like to see a bit further than the norm output is.
Old 03-15-2010, 09:09 PM
90CivicSI-hb's Avatar
Default Re: help with high/low beams
i know this dosent answer your question but i have a 90' civic si and im looking into buying new bulbs, i just have regular stock headlighs, so im pretty sure the low beam bulbs are 9006 and the high beams are 9005. am i right on this or not?
Old 03-15-2010, 09:20 PM
xalents23's Avatar
Why don't you buy a true dual H4 hid kit which comes with low and high beams.
93formula
11-24-2008 11:52 PM
rsdriver17
Lighting
03-05-2008 11:03 AM
brianjec
Lighting
03-05-2008 06:00 AM
monalisa overdrive
11-02-2004 11:15 AM
dcaccord
02-25-2002 12:18 PM
Quick Reply: help with high/low beams
