Fog Light Wiring Help. OEM Switch to Aftermarket - Honda-Tech
Old 04-07-2009, 11:53 AM   #1
superchargedY8's Avatar
Default Fog Light Wiring Help. OEM Switch to Aftermarket
I have a 96 honda civic with an aftermarket fog light kit.
My fog light switch recenly went out so i purchased an OEM switch and apparently the OEM switch is quite different from the aftermarket harness. I have read that in order to connect the OEM switch with the after market harness i just need to match up the 2 ground wires, relay wire, and parking light wire. I am almost positive i know which are which on the OEM switch but I have NO IDEA which are which on the aftermarket harness
someone PLEASE help!!
This is the aftermarket harness:
(I need to know which wire is which)
This is the OEM switch.
(I am almost positive i know which is which on this one)
superchargedY8 is offline   Reply With Quote
Old 04-08-2009, 06:44 PM   #2
Default Re: Fog Light Wiring Help. OEM Switch to Aftermarket
If you already have the OEM fog light plugs behind the bumper, why not just wire the the after market lights to the OEM harness. If your worried about the load, just put a relay where the OEM fog would hook up and use the relay to control the aftermarket lights. Then they lights will work as they should, only only when Low beams are.
ControlNode is offline   Reply With Quote
Old 04-13-2009, 09:02 PM   #3
hazard2o9's Avatar
i dont know if this is going to help but you can try
http://www.honda-tech.com/showthread.php?t=2246130
hazard2o9 is offline   Reply With Quote
Old 04-21-2009, 11:15 AM   #4
thomas_garcia08's Avatar
i have the jdm foglight switch. it has four wires out of the back.
2- red with black stripe
2- solid black
i am not using the stock harness for the fog lights.
i bought the aftermarket foglight harness.
thomas_garcia08 is offline   Reply With Quote
2004-2005 TSX OEM FOG light DIY Installation Kilat29 Acura TSX 2 01-29-2012 05:39 PM
91 honda accord cb7 oem stanley foglight stevoslav For Sale 25 06-02-2009 01:27 AM
oem civic/crx fog light harness replica crx_si-r For Sale 4 06-19-2008 05:38 AM
92-95 civic fog light switch pinout diagram mulletov Honda Civic / Del Sol (1992 - 2000) 4 01-28-2007 03:47 PM
Need Help on wiring OEM Fog Light Switch MugenDC4 Acura Integra 5 05-18-2004 04:02 PM
Tags
2000, accord, aftermarket, civic, fog, harness, honda, how, jdm, light, lights, oem, rsx, switch, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
