Custom interior lighting, extra dome lights and LEDs in the pillars - Honda-Tech
Old 02-27-2017, 04:37 AM   #1
Dur Da Dur
hondur's Avatar
Default Custom interior lighting, extra dome lights and LEDs in the pillars
I wanted to do something purely appearance since I haven't done **** for that aspect of my car.
This is what I'm thinking, I'll add two extra dome lights above the driver and passenger seat, put two vertical strips of several LEDs in the B pillar, and star shapes of LEDs in the C pillars. Put some lights under the dash, too.. maybe near the floor in the back. If anyone has ideas on where else to put LEDs or lamp assemblies, please comment about that. All of that is going to be on a dash switch, and connected to the radio! I got the idea after I saw a product called Chromasilk Neon, and I think it'd be supra cool for my hair to glow in the black light which is flashing to the beat.
I don't understand how I can connect them to the radio, I don't want them to get too much power when it's turned up and I know I can use a resistor for that. But I want them to flash when the music is turned down too.. I read a little about this but didn't see any comprehensive guide, nor any sort of "this is undisputably the best way to do this". Help will be appreciated!
hondur is offline   Reply With Quote
Old 02-27-2017, 05:16 PM   #2
Default Re: Custom interior lighting, extra dome lights and LEDs in the pillars
I'm pretty sure if you look through these forums, there is already a step-by-step guide on how to do this. Even with pictures....I had a friend who had this done using the guide on this forum.
Good luck!
ash_teg1993 is offline   Reply With Quote
HIDs are dead and LEDs are in! H4 retrofits in LED form rock BrakeExpert Lighting 4 01-23-2017 10:39 AM
Least invasive way to turn on LEDs when door opens? (no toggle switch) Adam V Lighting 2 05-18-2016 09:09 AM
Eg civic led turn signal causes all lights to flash Cmorcivic Honda Civic / Del Sol (1992 - 2000) 2 10-27-2015 09:27 PM
Dome Light Circuit Questions Faraz123 Honda Accord (1990 - 2002) 2 05-27-2015 03:41 PM
DIY: Footwell LEDs on/off with Door DCiFound Lighting 4 07-13-2014 07:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
