Bumper light/Corner light/Fender light - Honda-Tech
Old 03-04-2010, 12:51 PM   #1
B16CRXVTEC's Avatar
Default Bumper light/Corner light/Fender light
hey HT. i am trying to wire my bumper light so it can stay on at night along with the corner and fender lights. i've manage to get the corner and fenders light to come on but im not able to get the bumper light to come onto.
so my question is which wire do i have to wire onto my bumper light? or what do i have to do? any info will help. thanks in advance.
B16CRXVTEC is offline   Reply With Quote
Old 03-05-2010, 06:41 AM   #2
PatrickGSR94's Avatar
Default Re: Bumper light/Corner light/Fender light
CRX? Bumper lights are turn signals only, are they not? If you wire them to be on all the time, what the heck will you use for turn signals?
Honestly, I wouldn't even try it. Those housings are not meant to have a 21-watt turn signal bulb filament on all the time, and the housing will eventually melt or deform, and probably short out the light socket.
You could try removing the socket and rigging up a dual-filament turn/park bulb (3-wire socket). Then just tap the power wire for the 5-watt filament off of your corner light wiring. That way you would still retain proper turn signal operation, and not worry about melting or shorting out anything.
PatrickGSR94 is offline   Reply With Quote
quick question.... DoubleDirtyC Honda CRX / EF Civic (1988 - 1991) 6 10-10-2010 08:06 PM
JDM side fogs. (cornering lights) and bumper pole wiring? huskyl3oi Honda Accord (1990 - 2002) 14 04-07-2008 05:20 PM
Fender Turn Signals honda94accord Honda Accord (1990 - 2002) 4 06-12-2007 05:27 AM
Turn Light DMF Honda Civic / Del Sol (1992 - 2000) 3 03-17-2003 11:43 PM
corner light blinkers not working, HELP TheBestCRX Honda CRX / EF Civic (1988 - 1991) 1 01-06-2003 08:19 PM
Tags
92, bulb, bumber, bumper, corner, crx, dual, ep3, filament, honda, light, lights, prelude, socket, stay, time
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
