accord parking lights not working - Honda-Tech
Old 05-16-2008, 11:12 PM   #1
huskyl3oi's Avatar
Default accord parking lights not working EDIT: working now. fixed
ok guys. my parking lights not working.
the list of stuff i already have done.
checked all fuses.
checked all connections.
swapped switch.
dont know what it could be any help would be appreciative.
oh and my head lights work high beams work signals work brake lights work.
dont know what it could be please help.
Modified by huskyl3oi at 11:35 PM 6/13/2008
huskyl3oi is offline   Reply With Quote
Old 05-17-2008, 09:54 AM   #2
huskyl3oi's Avatar
Default Re: accord parking lights not working (huskyl3oi)
bump someone please help
Old 05-19-2008, 12:35 AM   #3
huskyl3oi's Avatar
mid night bump.
anyone got any suggestions?
Old 06-13-2008, 04:08 AM   #4
huskyl3oi's Avatar
checked all fuses all relays under the hood: dimmer relay, headlight relay, checked all lights ascosiated with my parking lights bought all new bulbs. gonna crack at it tomarrow see what happens
if anyone can help would greatly appreciate it.
Old 06-13-2008, 02:38 PM   #5
huskyl3oi's Avatar
bump
Old 06-13-2008, 11:35 PM   #6
huskyl3oi's Avatar
fixed. there was a burnt wire undernieth the dash. red/black wire. im good to go now.
Old 12-23-2009, 08:42 PM   #7
Stackle2's Avatar
Quote:
I am having the exact same issue. No parking lights (front or rear), side markers, or dash dimmer lights. I replaced the headlight/turn signal control switch, replaced the small light fuse, and the fuse blows immediately. This leads me to believe I have an open short somewhere, which seems to be what you had wrong.
I would greatly appreciate it if you could explain where the red/black wire was, and what you did to fix it. I know there is a red with black strip that comes out of the dimmer control module, but when I put a multimeter across it it wasn't getting any juice.
Once again, thanks for the help!
Stackle2 is offline   Reply With Quote
Old 01-21-2010, 11:00 AM   #8
preynolds2's Avatar
same problem here.
where is that wire ?
preynolds2 is offline   Reply With Quote
Old 01-22-2010, 11:07 PM   #9
preynolds2's Avatar
anyone
anyone
FS: F22b1 203k obd1 huskyl3oi For Sale 4 04-11-2009 08:53 PM
CRX radio din gauges huskyl3oi Honda CRX / EF Civic (1988 - 1991) 5 01-17-2009 10:16 AM
FS-f22b1 motor and Apex'i pillowball mounts for eg dc db huskyl3oi For Sale 17 01-17-2009 10:08 AM
check out the intersections huskyl3oi Honda Accord (1990 - 2002) 4 05-12-2008 10:01 AM
JDM side fogs. (cornering lights) and bumper pole wiring? huskyl3oi Honda Accord (1990 - 2002) 14 04-07-2008 05:20 PM
Tags
2001, 94, 97, accord, brake, dash, dimmer, honda, light, lights, parking, relay, signals, turn, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
