Lighting HID/Xenon kits, Retrofits and Associated Topics
97 Accord lighting questions
Old 08-15-2007, 07:37 PM
WillEat4F00d's Avatar
Default 97 Accord lighting questions
How do I take out my marker lights (the driver's side)? I want to change one of the two bulbs. Also, there is water that is stuck to the glass, how would I get that out?
Another question that I have is, how do I change the bulbs in the dash? I'm not talking about the gauges or needles. What I'm talking about sits the "ceiling" of the dash. I can see two bulbs there.
Thanks for looking.
Old 08-15-2007, 07:53 PM
He knows where you live!
TheMuffinMan's Avatar
The lights in the ceiling there shold be a small indention for a small flat head scrwedriver to slide in and pop off.
And assuming you're talking abotu the corner lights, there's one screw on a plastic arm that holds them to the main headlight, then they pop out (pull forwards)
Old 08-15-2007, 07:58 PM
The-Kid's Avatar
Default Re: (TheMuffinMan)
No, he is not talking about the map lights. I hope not.
I think he is talking about the gauge lights, inside. Sort of like spot lights. Removing the gauge cluster is really hard on the 5th gen. Look at the Muffinman's write up on removing it. (Located in the Accord FAQ... find it) Lots of work. The bulbs are either 194/168 (same as your corner lights) and 74.
Hope this helps.
Old 08-16-2007, 05:39 AM
AHHH yeah I was not even thinking about those ones.
You'll have to remove the cluster to get to them - like The-Kid said, there's two of the "cluster removals" awdgsx added to mine and put pictures to it
Old 09-08-2007, 08:55 PM
JDM_Acccord's Avatar
the bulb type is in fact 194/168?
dragracer7383
02-04-2019 03:36 PM
mooneybeams
03-17-2007 08:37 AM
claytonsmith
03-01-2007 10:10 PM
accord4life
08-26-2005 10:09 PM
Quick Reply: 97 Accord lighting questions
