Wiring fuel pump relay with ktuned conversion harness. - Honda-Tech
Old 03-06-2017, 04:21 PM   #1
B_Swapped93's Avatar
Default Wiring fuel pump relay with ktuned conversion harness.
94 EG8. Before I go cutting my A7/A8 wires to splice for the fuel pump, I have one question. Do I cut a7+a8 then connect them both to the 1 wire on the harness labelled "fuel pump relay".
B_Swapped93 is offline   Reply With Quote
Old 03-08-2017, 03:43 PM   #2
Default Re: Wiring fuel pump relay with ktuned conversion harness.
Bump?
Help with EG-Kswap(electrical). ktuned conv harnees. B_Swapped93 Honda Civic / Del Sol (1992 - 2000) 12 03-07-2017 01:42 AM
Checking Main Relay, with pics!!! Ahknodd Honda CRX / EF Civic (1988 - 1991) 34 03-01-2017 12:02 PM
main relay and fuel pump trouble hatchz6 Honda Civic / Del Sol (1992 - 2000) 5 12-30-2009 05:39 AM
Wiring problems with fuel pump KansasKev Honda CRX / EF Civic (1988 - 1991) 10 06-01-2007 12:36 PM
need some help with fuel pump wiring... primeredsol Honda Civic / Del Sol (1992 - 2000) 14 12-21-2006 10:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
