What is this port on the water pump, can i block it?. - Honda-Tech
Old 02-18-2017, 03:46 PM   #1
B_Swapped93's Avatar
Default What is this port on the water pump, can i block it?.
I took the nipple out, that had a small hose on it, it would have ran to the stock k20A2 intake manifold. I've got the ktuned manifold now, but before I put it on, i'd like to know what that port is and if I can block it off. And if I can't, what CAN I do with it, I see no where on the manifold to put an oil? line into.
B_Swapped93 is offline   Reply With Quote
Old 02-18-2017, 10:11 PM   #2
stayontrack's Avatar
Default Re: What is this port on the water pump, can i block it?.
pcv valve
stayontrack is online now   Reply With Quote
Old 02-19-2017, 06:33 AM   #3
Quote:
Originally Posted by stayontrack View Post
pcv valve
thank you, I got rid of mine on any of the B series I had back in the day. I'm assuming it's ok to just put the bolt in there, nothing else needs to be done?
Old 02-19-2017, 08:24 AM   #4
been there done that
doood's Avatar
If you block that off I would run at least a catch can off the valve cover
doood is offline   Reply With Quote
Cruise Control Vacuum 96Miata! Honda Civic / Del Sol (1992 - 2000) 10 08-31-2016 08:48 AM
all motor b20v with STR intake mani.. any input? xxstuntin4life All Motor / Naturally Aspirated 4 06-18-2012 12:36 PM
im having some problems ej1252 All Motor / Naturally Aspirated 9 06-03-2008 12:00 AM
b series motor soon2bdropped Honda Civic / Del Sol (1992 - 2000) 6 07-13-2007 10:57 AM
97 GSR port and polished IM Train Acura Integra 6 12-06-2002 04:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
